FW13 Pro (Intel) does not charge with UGreen Nexode Pro 300W
Which Linux distro are you using? Fedora Kinoite
Which release version? Stable
Which kernel are you using? 7.2.11-200.fc44.x86_64
Which BIOS version are you using? 03.02
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) Intel Core Ultra Series 3
I am running into issues with charging my laptop using various high power multi-port powert chargers. I should note that NONE of my other laptops seem to have this issue, it is only my brand new Framework 13 Pro. It seems incredibly sensitive to what charger it wants to use.
Welcome to the forum.
My 13 Pro (AMD) is fine with my Dell docking station, my Dell XPS charger, and a UGreen power supply. We have a different BIOS though, so perhaps they aren’t comparable.
Do you get anything in dmesg or journalctl when connecting to a charger that doesn’t work?
Also, which of the four expansion card slots are you using for the USB-C card? It might be worth trying all possible slots, and if that doesn’t make a difference, consider trying the same again, but with all other expansion cards out.
