FW13 Pro (Intel): Ultra 5 325 vs Ultra X7 358H for a dev/research workload on Linux?
Hi all,
I’m about to order a Framework Laptop 13 Pro (Intel, DIY) as my personal Linux laptop. I’m hesitating between the Core Ultra 5 325 and the Core Ultra X7 358H.
My workload:
  • Antigravity IDE plus 2–3 Claude Code CLI agents running at the same time
  • LaTeX (latexmk on a thesis-length document)
  • Firefox with many research tabs
  • No gaming.
  • Light Python use: matplotlib, Hugging Face downloads
  • No heavy compute. I use Colab and HPC for that.
Questions:
  1. Has anyone run both chips on Linux? Is the X7 358H noticeably snappier for this kind of mixed dev workload, or is the difference only visible under sustained multi-core load?
  2. How do the two compare on battery life and fan noise for light or medium use? Does the 358H run hotter or louder in the 13" pro chassis?
Thanks!
Welcome to the forum!
I have the AMD AI 7 350, so I can’t answer directly, but I see that performance-wise it is between your two options.
Agents themselves don’t take much CPU, but it depends what they’re doing locally: mine run database and browser tests, which tends to be a heavier workload. I am happy with the performance, battery life, and fan noise; for my workload I probably get 3-4 hours, but I expect that, and I carry a PD battery with me anyway.
I’d say if you’re in doubt, go for the more performant of the two. However, if you are balancing budget across compute and RAM, it would be perfectly understandable to boost your memory size and then go for the lower CPU option. I have in mind your Firefox tabs here, and would say that 32GB is probably the minimum I’d recommend: what size were you thinking of getting?
Thanks for the answer.
I am definitely going for 32 gigs even if it’s expensive.
But was wondering if the 500€ increased price between the Ultra 5 or 7 is worth it.
Also should I get the AMD?
I saw that the new Panther lake is much more efficient and the AMD is not recommended
what are your thoughts on that.
Thanks.
I preferred the AMD as there is an Intel boycott at present, and I wished to respect that (I think we have a soft rule here not to discuss politics in order to prevent a bun-fight, so I will refrain from elaborating).
But AMD has other things going for it: at least at the 64 GB point, normal DDR5 is about half the price of LPCAMM2, is more widely available, and with generally better levels of compatibility. For me, LPCAMM2 would have been another £800 on top of an already high spend.
Certainly, yes, the Intel options are more power-efficient - see my link for details. A lot of this is about whether you can chuck money at the problem, whether you can carry a PD battery, how long you expect to be away from a power socket, etc. I think Intel has developed some clever ways to turn off parts of its chips that aren’t being used, but of course predicting the power usage for your workload basically requires you to buy it and try it out! You can of course do this, under the 30 day returns policy, but then you’re potentially signing up for another wait to get a second unit.
Personally for my mix of needs, access to batteries, access to power in cafes, etc, I am very happy with my AMD choice, and the Pro is a very stable bit of kit all-round. I was running a Dell XPS 15 previously, and it was fine as a workstation, but rather heavy for lugging about.
First of all I understand and agree for the boycott (will also avoid politics though)
Second, this is literally my case. I had a chunky XPS15 with a GPU that is now no longer usable given the compute I need.
I am also moving a lot more often and it’s far too heavy for me to carry around.
Thank you for your answer, I might actually end up settling for the AMD after all.
For having both, (Intel x7 and amd HX 370). I very much prefer the AMD HX 370. More efficient, more powerful (except the GPU, GPU is the only thing that’s better on Panther Lake), better linux driver and more generally, more invest in open source
(I had spotted that your most recent post got caught up in a forum content filter, I don’t know what that was about! Anyway, it appears now to be restored, thankfully).
Well, I can certainly recommend the AMD direction, even though I’ve not tried the Intel. I did mildly ponder if the Ryzen AI 9 would have been better than the Ryzen AI 7, but it was another cost trade-off: did I really need to spend another £250? I am pleased where I ended up, anyway.
