FW13 Pro Limited Batch (X9) Guild
More than a week has passed since the payment, but I still have no tracking number. Is anybody from the Framework team here? Could you please clarify the shipping timeframe? :cry:
Drop a PM to @Eagle with your order number, who can look up that information for you.
Thank you, I wrote to him, but received the tracking number even before he responded. Now I’ll wait for delivery :crossed_fingers:
Who knows, maybe someone gave it a nudge :star_struck:
Mine was stuck too.
I filed a ticket on Friday. Got a response with an apology. And the device is currently leaving the beautiful place known as Taiwan :slight_smile:
I’ve just received my Framework 13 Pro. It’s a shame, but I can’t write a review of the laptop yet because every time I turn it on I get the “Memory not properly installed” error (code 0xDF28). I tried reinstalling the memory about 10 times, always getting it perfectly aligned, but I also adjusted the screw tension. Ultimately, nothing worked, the error persisted, and what’s more sad, one of the screws was already a little worn out from constant tightening.
I also checked that all the pins were intact and there were no dust particles on the contacts. The only odd thing I noticed was some stains on the memory. But I doubt that’s the cause of the failure.
I suspect the memory module is defective, but maybe the problem is in the interposer. But I’m almost 100% sure it’s not a “uniform screw tension” issue because I’ve tried too many different levels of tension, and none of them worked.
Does anyone know if this memory is tested at the factory? Does the Framework test it? I mean, is there any point in trying again, or should I open a ticket?
Maybe you guys had the same issue and have an advice how to get it working?
Update: It seems I was wrong about the pins. After all, one pin in the interposer is definitely broken. Can I get a new one?
If you need one fast, they are available from typical electronic parts vendors Access to this page has been denied.
Thank you, I ordered yours, and also this one Access to this page has been denied. I really hope the replacement will help. Delivery is promised within 4 days, so I will write about the results within a week.
So mine was late a week as well. And I also had this error and when I disassembled the damn thing I had a broken pin on the interposer.
<tinfoil>Interesting</tinfoil>
