OS: Win11 24H2 26100.7462
FW16 Ryzen™ 9 7940HS w/ AMD Radeon™ RX 7700S (1st Gen)
BIOS: 4.02 w/ current drivers from 11-12-25 pack.
Following the advice on the FW16 section of the forum, I am attempting to get a single cable dock setup to be functional. I have an additional USB-C dongle on the way to test a two cable setup, but one cable, even with the reduced wattage, would be my preferred setup. I am currently utilizing a Wavlink Dock that was linked in late 2024 discussions as the highest passthrough power (125W) while being compatible with a multiple monitor setup.
I am using the Framework 180W brick to power the dock, and when connecting the dock to the machine via Port 1 (back left when machine is open) Windows will give multiple notifications, and cycle the port so that power disconnects and then reconnects indefinitely.
The dock never ‘connects’ to the system enough to even attempt to pull up the displays, or USB devices attached to the dock. I have also tested this with nothing running to or from the the dock other than power. I have the most recent DisplayLink drivers with HotDesking installed. I have also reinstalled these drivers utilizing the DisplayLink cleaner. Looking for any tips on getting this setup functional. I know at 125W that I will experience battery drain under high utilization, but my general day-to-day utilization is rarely that high.
PLEASE READ BEFORE POSTING:
Are you looking into the forum because you’re having potential issues with your Framework product? Before creating a post, we may have a guide, FAQ, or thread that can hopefully help!
In the body of your post, please include those following details.
- Which OS (Operating System)?
- Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
- Which Framework product (Laptop 13, Laptop 16, Laptop 12 or Desktop) and which generation of CPU (Intel 11th gen, Intel 12th gen , Intel 13th gen, Intel Ultra Series 1, Chromebook, AMD 7040 Series, AMD AI 300 Series, AMD AI Max 300 Series) or GPU (NVIDIA® GeForce RTX™ 5070, AMD Radeon™ RX 7700S)
If there is no information pertaining to your issue or question, please let us know here: Framework | Support https://frame.work/support
