FW16 RTX 5070 rear USB-C stopped detecting displays across reboots, only a full power-off fixed it
Has anyone else had the rear USB-C port on the NVIDIA graphics module stop detecting a monitor, with only a full power-off bringing it back?
Setup
  • Framework Laptop 16 (Ryzen AI 300), BIOS 04.01, EC tulip-4.0.1, PD firmware 0.0.22 on all controllers
  • RTX 5070 graphics module (framework_tool --expansion-bay: enabled, no fault, EEPROM valid)
  • Ubuntu 26.04 (kernel 7.0.0-38, NVIDIA 595.99.02 open), Cinnamon on X11, dual-boot with Windows 11
  • Acer ET322QU on a USB-C to DisplayPort cable, which normally lives in the rear dGPU port. Dell WD19TB dock and the power adapter are on side ports.
What happened
  • After a day of updates and several restarts, the monitor stopped being detected on the rear port.
  • The same cable and monitor worked fine on a side USB-C expansion card (iGPU) the whole time.
  • On the rear port nothing registered at all. The kernel logged only ucsi_acpi USBC000:00: unknown error 256, the USB-C connector never picked up the monitor or
    switched into DisplayPort mode, and the NVIDIA DisplayPort output stayed disconnected.
  • It stayed dead across multiple warm reboots and two kernels, and with NVIDIA dynamic power management both on and off.
What fixed it
  • I fully powered the laptop off, reseated the side expansion cards and cleaned it (compressed air). Then I booted Windows 11, and the rear port worked. I rebooted
    into Linux, and it works there too.
  • The software is identical between the last failing boot and the working one: same kernel, driver, packages, config and firmware. So it looks like something in the
    rear port’s USB-C, power-delivery or retimer path got stuck, and only a full power removal reset it.
What the logs don’t show
  • No NVIDIA Xid errors, no PCIe AER errors, and no expansion bay faults. The GPU renders and sleeps normally.
Questions
  • Has anyone seen the rear port get stuck like this? Did a full power-off fix it for you, or did it keep coming back?
  • Is this a known PD or retimer firmware issue, or a sign the port or module is starting to fail? It’s under warranty, and I’d like to catch a failing port early.
Happy to provide additional details and/or logs if anyone is interested.
Kinda. The PD controllers in all Frameworks are notorious for shutting down due to a supposed overcurrent or some other issue of this sort - sometimes it’s enough to restart the device, other times you have go the “disconnect battery” route to get it to function normally again. The GPU expansion card has a PD controller of its own, which is why you’ll likely see just this port acting out.
The other day, I got “dirt of moisture detected in charging port” on my phone when I plugged it in to port 1 - something really crazy is going on in there and I think that the PD controller is preventing an even worse outcome.
This error always comes up no matter what, even when all ports are working fine. Its a Framework/AMD quirk. I run Fedora with the latest 7.2.11-200 Kernel and this message has shown since the day I have had this Laptop easily 10 Kernels and multiple firmware updates. I don’t even run a DGPU.
Ignore that error message as it will chase you down a false rabbit hole. All my ports work.
Mine:
CPU: Ai9 (HX370)
GPU: IGPU 890M
Yep, I’ve been having this same problem. I’ve extensively documented my working with Support on it here:
It appears to be part of a wider PD issue with AMD, and BIOS updates are planned to fix this later this year.
Same here. I’ve been running CachyOS, tried swapping kernels, running Windows off a storage expansion card (not a fantastic experience, but gets the job done). Didn’t know that it would work again after a full power cycle though.
Edit: Definitely works again after doing a full power off followed by starting it up with all the expansion cards removed. I’ll also note, that when I connected my monitor (complete with a USB hub and USB-C charging LG 38WR85QC-W) to the GPU via a USB-C to USB-C cable the display repeatedly disconnected and reconnected. It seems to work fine over HDMI but is capped at 60hz, markedly lower than the full 144hz I could select when I first installed my 5070 in November/December.
I also get this on Windows 11 if I shut down or hibernate with a monitor connected to be back port on the 8GB version. I have tried both with a usb-c displayport cable and a usb monitor. I shut down and unplug all usb devices and power for a minute, then turn back on and plug everything back in.
