FW16 Ventilation Plate
In the github files for the framework 16, the stp file does not contain an accurate ventilation plate, the bracket appears to be missing screw holes for holding down the ventilation plate as well as holes for the finger print sensor to be screwed into.
Is there anyway we can get a STP file that contains an accurate ventilation plate?
Thanks!
