Guix/PantherX on Framework 12
I haven’t seen any recent posts discussing Guix on any of the models, let alone the FW12. I plan to upgrade to the new Core 5 board in the future but in the meantime, curious if anyone has gotten either to work on the Gen 1 FW12.
I’ve used NixOS on this model and although it’s kind of a pain to fix certain things, it works fine for what my current uses are. But i’ve been really getting into Lisp and Emacs recently and Guix uses Scheme which I think is really cool and potentially really useful for my setup.
The issue is that there’s very little documentation on the distro(s) so fixing stuff sounds like a real pain. The other issue I’ve seen is that Guix in its installer is very strictly the Linux Libre Kernel, which is nice in principle but obviously runs into problems on the vast majority of machines, whether it’s the wifi card, audio, display, and all kinds of things. Switching out the kernel tends to break things too.
PantherX includes the mainline kernel (obviously compatible with FW12) but I’m just not sure what other issues can arise. For example, the touchpad on NixOS (and even some other distros/environments) won’t work on the FW12 without some workarounds. While not complicated, still feels overly tedious. I plan to immediately switch to the Gen2 keyboard with open firmware (and backlighting) pretty much day one it’s available as a solo unit, but I’m currious if anyone got anything working with the current Gen 1 FW12 and what your experience is like.
If people say it’s kind of tedious and prone to breakage (or just don’t get a response lol), i’ll probably just add the Guix Daemon inside NixOS which will sort of serve almost the same purpose for me.
the touchpad works fine on my fw12 on NixOS and other distros I’ve tried too fwiw. Haven’t tried Guix but you will need to get a non libre kernel (or replace the wifi with one of those old cards that have the firrmare burned in instead of loaded by the os). I think nonguix is what that repo is called that has proprietary firmware and a kernel that can load it.
