I have this same SSD case, and several others. I’ve connected both SATA 2.5" SSD’s and NVME SSD’s to the FW 16. I have found that the power delivery capabilities of the FW 16 are not really up to par with the needs of external storage, and my experience trying to use such things has been generally terrible. The most success I’ve had is in plugging in 1x sata ssd over usb (not type c), which works, but then I have issues with other devices not receiving enough power such as my wireless headset dongle. Not immediately, but over several hours of usage problems arise every so often.
Unfortunately, the best solution I have for you is to try not needing external storage. I saw this as someone who had 3x 4TB drives velcro’d to the back of my display. Alternatively, you could try plugging them in via an externally powered USB hub. I have not tried that yet.
I have a different version of it “SABRENT Tool-Free NVMe & SATA M.2 SSD Enclosure, USB 3.2 Type-C” that I bought back in 2023 and 2022. I can use them on any port I want. I haven’t had any power issues with it. I have an old FW16 the AMD Ryzen 7040 Series. Maybe the version of the ssd case I use requires less power?
Although I think if you have multiple high powered devices plugged in at once, there might not be enough power available?
Ports 1,2,4,5 are shared on a first come first serve basis. So they are 1.5A by default, but one port from any of these can negotiate 3A over PD. Once that is taken, the other ports are limited to 1.5A. Ports 3,6 are 900mA.
AFAIK the 7040 have a 5V 3A supply per side of ports. Its likely down to power negotiation, cable, etc.
5V 3A shared per side is not great, but it should be sufficient. I can run my wireless charger (5V 2A+) off of any of those, so this shouldnt be a issue.
USB-A 3.0 usually will do at least do 5V 900mA. This is likely a firmware issue with USB ports.
Try different cables, shuffling expansion card slots around, and maybe restart the computer.
Few words on this nvme case that I also own (and having 7840 fw16):
I had so many troubles with at the point I thought it was my nvme that was failing (especially on high nvme activity like Steam patching game).
Long story short → After many tests around my nvme, I bought a ugreen usb4 @ 40gbps enclosure and now all my issues are gone.
This case is unreliable !
