Hey gang, just purchased a new Framework 13 with the AMD Ryzen AI 9 HX 370.
Did a fresh Linux Mint (Cinnamon) install and then updated the bios with fwupdmgr.
My HDMI card is in “Slot 1” as explained by this diagram: Expansion Card Functionality on Framework Laptop 13 (AMD Ryzen™ AI 300 Series)
Swapping the slot that the card is in did not seem to help, so I was wondering if I missed anything else common? inxiresults below:
kev@kevs-framework:~$ inxi -Fxz
System:
Kernel: 6.17.0-19-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Console: pty pts/0 Distro: Linux Mint 22.3 Zena base: Ubuntu 24.04 noble
Machine:
Type: Laptop System: Framework product: Laptop 13 (AMD Ryzen AI 300 Series)
v: A9 serial: <superuser required>
Mobo: Framework model: FRANMGCP09 v: A9 serial: <superuser required>
UEFI: INSYDE v: 03.05 date: 10/30/2025
Battery:
ID-1: BAT1 charge: 60.6 Wh (98.1%) condition: 61.8/60.7 Wh (101.9%)
volts: 17.4 min: 15.5 model: NVT FRANGWA status: discharging
CPU:
Info: 12-core model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64
type: MT MCP arch: N/A rev: 0 cache: L1: 960 KiB L2: 12 MiB L3: 24 MiB
Speed (MHz): avg: 726 high: 2115 min/max: 605/5158:3289 boost: enabled
cores: 1: 2115 2: 605 3: 605 4: 605 5: 605 6: 605 7: 605 8: 605 9: 605
10: 605 11: 605 12: 605 13: 605 14: 605 15: 605 16: 605 17: 605 18: 605
19: 605 20: 605 21: 605 22: 2001 23: 605 24: 605 bogomips: 95820
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: AMD vendor: Framework driver: amdgpu v: kernel bus-ID: c1:00.0
temp: 40.0 C
Device-2: Framework Laptop Webcam Module (2nd Gen) driver: uvcvideo
type: USB bus-ID: 3-3:2
Display: server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
tty: 80x24 resolution: 2880x1920
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
active: gbm,surfaceless,device inactive: wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.2.8-0ubuntu0.24.04.1
note: console (EGL sourced) renderer: llvmpipe (LLVM 20.1.2 256 bits), AMD
Radeon 890M Graphics (radeonsi gfx1150 LLVM 20.1.2 DRM 3.64
6.17.0-19-generic)
API: Vulkan v: 1.3.275 drivers: N/A surfaces: N/A devices: 2
Audio:
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Framework
driver: snd_hda_intel v: kernel bus-ID: c1:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Framework
driver: snd_acp_pci v: kernel bus-ID: c1:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Framework
driver: snd_hda_intel v: kernel bus-ID: c1:00.6
API: ALSA v: k6.17.0-19-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Device-1: MEDIATEK driver: mt7925e v: kernel port: N/A bus-ID: c0:00.0
IF: wlp192s0 state: up mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Bluetooth:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB
bus-ID: 3-5:3
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives:
Local Storage: total: 1.82 TiB used: 84.78 GiB (4.6%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN7100 2TB
size: 1.82 TiB temp: 34.9 C
Partition:
ID-1: / size: 1.79 TiB used: 84.56 GiB (4.6%) fs: ext4 dev: /dev/dm-1
mapped: vgmint-root
ID-2: /boot size: 1.61 GiB used: 218.8 MiB (13.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-3: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 1.91 GiB used: 0 KiB (0.0%)
dev: /dev/dm-2 mapped: vgmint-swap_1
Sensors:
System Temperatures: cpu: 45.8 C mobo: 40.0 C
Fan Speeds (rpm): fan-1: 0
Info:
Memory: total: 128 GiB available: 125.09 GiB used: 2.39 GiB (1.9%)
Processes: 507 Uptime: 1m Init: systemd target: graphical (5)
Packages: 2130 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
kev@kevs-framework:~$ xrandr --query
Screen 0: minimum 320 x 200, current 2880 x 1920, maximum 16384 x 16384
eDP connected primary 2880x1920+0+0 (normal left inverted right x axis y axis) 285mm x 190mm
2880x1920 120.00*+ 60.00 +
1920x1200 120.00
1920x1080 120.00
1600x1200 120.00
1680x1050 120.00
1280x1024 120.00
1440x900 120.00
1280x800 120.00
1280x720 120.00
1024x768 120.00
800x600 120.00
640x480 120.00
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
DisplayPort-3 disconnected (normal left inverted right x axis y axis)
DisplayPort-4 disconnected (normal left inverted right x axis y axis)
DisplayPort-5 disconnected (normal left inverted right x axis y axis)
DisplayPort-6 disconnected (normal left inverted right x axis y axis)
DisplayPort-7 disconnected (normal left inverted right x axis y axis)
