Which Linux distro are you using?Linux Mint
Which release version?
(if rolling release without a release version, skip this question)22.3 Cinnamon
Which kernel are you using?7.0.0
Which BIOS version are you using?3.07
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)Intel Core Ultra Series 1
I tried a switch to kernel 7.0.0 after someone mentioned that it was better for my laptop while I was dealing with other issues. However, a big problem I had with that kernel is that whenever I would unplug the HDMI cable that runs to my TV, it would take a long time (at least a good 5-10 seconds) to register that anything had happened, and then afterwards I would have a horrible screen lag, such that I would need to reboot the computer in order to do anything. I was told it’s a Framework problem because nobody else has had any such issues, so I’m asking here what to do about it. I’ve switched back to kernel 6.8.0 for now, but I’ve heard that 7.0.0 is going to be the default kernel for the next version of Linux Mint, and I want to be prepared, especially as I understand that Wayland is necessary to get the screen to look good on Framework laptops (as the HiDPI display requires fractional scaling - 100% is too tiny, but 200% blows everything up and has it looking like an old 90s CR% display with no screen real estate). Can someone please help me fix this problem?
Just use the kernel that works. 6.8.x is supported until April 2029, so it is still a very current system. If you pin to this version, do your problems go away?
If you were to install another version of Mint then yes, you might get a new kernel. This is why it’s worth testing a new OS thoroughly before committing to it.
My fresh Mint 22.3 installation uses Cinnamon 6.6.x and this is still on X11. I did some research and found that some features I need are still not implemented in Wayland. I don’t have an ideological preference between the two, I just want stuff to work. I would not prefer Wayland because the system is newer.
Sticking with 6.8.x resolves that particular issue, but I have other screen issues that have been a problem on it. In particular, the screen is subject to randomly blacking out and requiring a Cinnamon restart to function again (and if I get that once, I’ll likely get it several more times that day; other days, I never see it at all); I don’t know what exactly causes that but I think it’s related to power management, as I often see it when the computer decides to start using power from the charger vs. the battery or when playing a video on YouTube. My screen settings are also a thorough compromise that I’ve never been happy with; I’m currently running at 1920x1200, even though text is a little small on that and it doesn’t utilize the full screen, because the native 2256x1504 looks terrible at both 100% and 200% scaling; fractional scaling is needed to make that work, but I get terrible screen tearing with it.
I have traditionally upgraded to new LTS releases of Linux Mint as they come out; this would be the first time that would be a big problem. I really want to do so, not just because of Wayland, but also other issues, like the audio glitch the version of VLC in the 22.x package base has, and also because it helps to periodically refresh the computer.
