After upgrading my framework 16 laptop with an Nvidia 5070 and updating firmware I can’t get my laptop to turn on! Does anyone else have the same problem?
How long have you let it sit there? I’ve never seen it happen, but I suppose it’s possible the RAM timings might be getting retrained, which could take like 30 minutes of just showing a black screen.
I guess I could try waiting 30 minutes
I experienced something similar - it sat there for several minutes, screen dark and just the power button indicating that it’s on.
I started regretting updating the firmware, but then it snapped back to life.
Is there a charging light when you plug it in or any sort of debug light when you, for example take off the keyboard? if not then something might be shorting a power-rail. Check the interposer and make sure the connector surface is clean.
Have you tried it without all the expansion cards connected? I had a similar problem with a new one (similar spec to yours) and it turned out to be a Logitech mouse wifi receiver in one of the USB A ports. Changing ports sorted it completely
Might sound weird, but potentially removing and re plugging the graphics interposer could work. I did that the first time I upgraded to the 7700s GPU because I had a similar issue occur, but it was more the system wasn’t recognizing the GPU. Not sure why it worked, but it somehow did for me.
I ended up taking it to a local computer repair shop and they got it to post although windows 11 bitlocker became an issue. I retrieved the bitlocker code and was able to successfully boot, but now the keyboard doesn’t work intermittently. Ugh!
Did you update the keyboard firmware?
yes, i just did and now my framework 16 only works with an external keyboard. let me try rebooting.
They had warned about that the keyboard needed a different firmware for the latest system BIOS. Worked for me.
It turns out the keyboard connections needed to be seated more properly, everything is working fine now!
Good one. Yes, that would have been the next thing I’d have checked.
