I am wanting to do some benchmarking of my Framework 16 Laptop using the Phoronix Test Suite. I downloaded PTS from here. I’m wanting my benchmark results to show temperatures, but I’m not seeing anything reported. For example if I run this command:
./phoronix-test-suite run blender MONITOR=sys.temp,cpu.temp,gpu.temp,hdd.temp
I don’t see anything for temperatures on the Results Viewer page. If I run this benchmark command but use MONITOR=all instead I still don’t get any sensor info. The results always look the same with or without the monitor parameter. I can at least go to View System Logs and select the sensors drop down to view temperatures but I would still like to see this info reported directly on the Results Viewer page. If I run the system-sensors command I see plenty of available sensors and nothing shows as unavailable or unsupported.
Also, is there any way to specify what device to run PTS against? Listing all available tests shows what they use by default (Graphics, Processor, System, etc) but it’s unclear to me whether or not you can specify what the test uses instead of the default options.
System Specs
Linux Distro: Fedora 43 Workstation Edition
Kernel version: Linux 6.19.8-200.fc43.x86_64
BIOS version: v04.03
Framework Laptop 16 model: AMD Ryzen 7040 Series with AMD Radeon RX 7700S dGPU
