High power drain when suspended due to ACPI table, with workaround
Framework Laptop 12 (13th Gen Intel): s2idle never reaches S0ix on Linux because BIOS sets STD3=1, keeping the NVMe root port (PEG0) in D0
This report and debug process are AI-aided. I have no deep understanding of ACPI/BIOS/firmware/Linux kernel. Related code and debug helpers, including the workaround kernel module, are on GitHub at GitHub - Ronmi/fw12-s0ix-debug · GitHub (written in Traditional Chinese). The module is a proof of concept for this report, not a recommended fix; use it at your own risk.
Summary
On the Framework Laptop 12 (13th Gen Intel Core), s2idle on Linux never reaches S0ix: the CPU package never goes deeper than PC3, and the battery drains about 3–5 %/hour while suspended (about 30 % overnight).
The cause is in the firmware’s ACPI tables. The GNVS variable STD3 is 1 (Storage D3 enabled, but not RTD3). \_SB.PC00.PEG0._INI copies it into PEG0.RD3C, and with RD3C != 2:
  • PEG0._S0W returns 0 (D0), so the OS must keep the CPU PCIe root port of the NVMe SSD (00:06.0) in D0 during s2idle, and
  • PEG0.GPRS returns 0, so the PXP power resource _OFF/_ON are no-ops.
When RD3C is forced to 2 at runtime, everything else stays the same and the firmware’s own RTD3 path works perfectly. The root port and the SSD go to D3cold, the package reaches PC10, the system spends 99.8 % of suspend time in S0i3.0, and drain drops to about 1 %/hour. Resume is reliable.
System
Item Value
Model Framework Laptop 12 (13th Gen Intel Core), board FRAPMACP05 rev A5
CPU Intel Core i5-1334U (Raptor Lake-U)
BIOS 03.07 (02/10/2026), 03.08 (08/20/2026) and 03.09 — all affected
SSD Kingston NV3 2230 (SNV3SM31T0, SM2268XT2, DRAM-less, HMB), firmware SDX01100
OS Debian 13, Linux 7.1.13 (backports) and 7.2.6
Sleep mode s2idle (default; deep is also offered)
Symptoms
  • /sys/kernel/debug/pmc_core/slp_s0_residency_usec and the S0i2.0/S0i3.0 substate residencies stay at 0 after every suspend.
  • With intel_pmc_core.warn_on_s0ix_failures=1, the kernel reports CPU did not enter Package C10!!! on every resume. Package C6–C10 counters stay at 0, and only PC2/PC3 increase.
  • There are no spurious wakeups; the only wake event is the lid (EC GPE, IRQ 9).
  • Intel’s S0ixSelftestTool reports: “Your system achieved PC3 residency, but no PC8 residency during S2idle”. It also reports that pcieport 0000:00:06.0 stays in D0 (PCI PM: Skipped) and that its link is only in L1, not L1.1/L1.2.
Analysis
Firmware logic (from SSDT “SaSsdt” and SSDT “ADL-P-M”, BIOS 03.08)
SSDT SaSsdt (rev 0x3000), \_SB.PC00.PEG0._INI:
If ((\_SB.PC00.PEG0.PEGP.PNVM () || \_SB.PC00.PEG0.PEGP.PAHC ()))
    \_SB.PC00.PEG0.RD3C = \STD3
SSDT ADL-P-M, \_SB.PC00.PEG0:
Method (_S0W, 0, NotSerialized)
    If (CondRefOf (RD3C)) { If ((RD3C == 0x02)) { Return (0x04) } }
    Return (Zero)                                   // D0
Method (GPRS, 0, NotSerialized)                     // gate used by PXP._ON/_OFF
    If (CondRefOf (RD3C)) { If ((RD3C != 0x02)) { Return (Zero) } }
    Return (One)
\_SB.PC00.PEG0.PEGP._S0W similarly returns 3 (D3hot) instead of 4 when RD3C != 2.
Since STD3 != 0, PEGP._DSD still exposes StorageD3Enable = 1, so Linux puts the SSD into D3hot (“simple suspend”). However, the root port is not allowed below D0. On Linux, for S0 the _S0W limit is applied whenever the device has _PRW, regardless of the user’s wakeup setting.
Runtime values (read from GNVS at 0x448F9018 on BIOS 03.08)
Variable Value Meaning
OSYS 0x07DF sanity check (Windows 2015 _OSI)
STD3 1 Storage D3 only, not RTD3
SD2P / SDP1 0x0908000E / 1 SSD power-enable GPIO pad, active high
SD2R / SDR1 0x090C0014 / 0 SSD reset (PERST#) GPIO pad, active low
PEP0 100 power-on delay (ms)
The RTD3 GPIOs are configured, so the hardware path is clearly wired. Only the STD3 value keeps it disabled.
Kernel trace confirming the D-state decision
A kprobe on acpi_pm_device_sleep_state() during suspend (stock BIOS tables):
dev="0000:00:06.0"  ret=0     # root port: firmware allows D0 only
dev="0000:01:00.0"  ret=3     # NVMe: D3hot only
With RD3C = 2:
dev="0000:00:06.0"  ret=4     # D3cold
dev="0000:01:00.0"  ret=4     # D3cold
pcieport 0000:00:06.0: PCI PM: Suspend power state: D3cold
nvme 0000:01:00.0: PCI PM: Suspend power state: D3cold
Measurements
All runs are on battery with the dock unplugged and the lid closed. The drain figures include the few minutes the system was awake around each suspend.
Configuration Suspend time S0i3.0 residency Package C10 Drain
Stock BIOS 03.07 ~15 min 0 0 72 mAh in 18 min (≈ 5 %/h)
Stock BIOS 03.08 ~39 min 0 0 87 mAh in 40 min (≈ 3 %/h)
Stock + nvme.noacpi=1 (SSD kept in D0/APST) ~64 min 0 0 (PC2 only) 288 mAh in 66 min (≈ 6 %/h)
RD3C = 2 via SSDT override (initrd) ~51 min 3021 s (99.8 %) 3024 s 33 mAh in 51 min (≈ 0.9 %/h)
RD3C = 2 via runtime method (no table replaced) ~37 min 2243 s (99.8 %) 2245 s 32 mAh in 38 min (≈ 1.2 %/h, microSD card inserted)
Battery: 4303 mAh full charge.
Things that were ruled out along the way, with no change in package C-state:
  • External display or dock
  • microSD expansion card (USB on the TCSS xHCI)
  • GNA (00:08.0) left in D0
  • Disabling wakeup on the root port
  • Package C-state limit (MSR 0xE2 allows PC10)
  • GPU RC6 (OK)
  • ltr_ignore_all_suspend (already on)
Workaround currently in use
A small out-of-tree kernel module loads a tiny SSDT (via acpi_load_table()) that adds \_SB.PC00.PEG0.FXRD, a method that sets RD3C, and calls it with 2 at boot. It only acts on a Framework Laptop 12 (13th Gen) (DMI check), when PEGP.PNVM() is true, and when SD2P/SD2R are non-zero. No firmware tables are replaced. (v1.0 used acpi_install_method(), which fails with AE_BAD_PARAMETER on Linux 7.2 due to an ACPICA regression fixed upstream in ACPICA 19429ef91.)
This works, but it is clearly something the BIOS should handle.
Although this looks like a firmware bug, STD3=1 may be intentional (e.g. to avoid resume issues with certain SSDs). If so, a BIOS option to enable Storage RTD3 (STD3=2) would be appreciated.
