I am having to do some extensive repair on a Framework 12 which was broken at the hinges. I ordered a new hinge kit, but it did not come with the little black cable clips that normally go in there to hold the 2 cables coming down on each side. Anyone know if those are parts you can order or if they should have come with the hinge?
You can’t order them. You’re shit outta luck if you loose them.
Fortunately they only seem to be a dust protection measure and not strictly necessary.
They really should include those in the box with new hinges at least. it’s a bit ridiculous.
For some reason I thought new hinges included them, but maybe I’m mistaken.
Nope. It’s the one part I know of that’s impossible to obtain if it gets lost or broken. And they do indeed bend and break if inserted wrong. I’ve done it a couple times.
My hinge kit did not include them and they were destroyed along with the old hinges.
That sucks. Maybe if you email support there’s a slim chance they could send you some but I wouldn’t hold my breath.
Well, if you can’t order that part then the notebook isn’t fully repairable. I already did open a support case as well.
That’s what I’ve been sayin lol
To be fair…I only got back half of the notebook, so it was a pretty extensive repair.
Yikes what happened??
I must just be misremembering. I swapped my case and hinges out in a bit of a hurry after work one day so I could make it to FedEx to ship the old parts back out. I remember messing with those little pieces, but not that I had to re-use the old ones. That’s a shame that there’s no way to get them.
do you have a picture of the clips? Do the come on either of the top or bottom shells?
They do not come with the shells (have both) or the hinge kit. They are the items in the yellow box.
Seems like there are efforts to get the clips made available. I will update this thread when I get back from travel with what I hear.
