Clarification:
That post is a misunderstanding. The framework hinge is non-adjustable, which as I said for the 4th time, seem to be a engineering oversight.
If your hinge is so loose it will fall flat, contact customer support. Framework have some tight hinges that they send out for replacement.
Mine seems to have become looser over time, and now will often fall flat if I have it open past 90 degrees and stand up/move around. Would also appreciate an option for a stiffer hinge.
+1 to needing a sturdier hinge. Mine also falls down to 180 degrees with just normal usage if it’s sitting anywhere past 100 degrees. I’ve had mine since 9/2021, it does seem to have gotten worse as time goes on, getting to be a real problem within the last month.
That’s their response. Kinda sucks, cause I don’t think I should have to pay to fix the fact that screen literally falls on its own, and still waiting on it. Guess that’s what repairable means lol, pay to fix design issues
@Norman_Paulino - if you can send them a video showing the screen opening due to its own weight while stationary on a table, I would be surprised if they did not consider it to be a warranty replacement. Mine wasn’t quite that bad, but it got on my nerves enough that I bought new hinges and replaced them. Now the screen is much more stable. If a stiffer hinge option is ever available, I’ll likely switch to that. These were pretty stiff when new, I’m trying to pay attention to whether they get looser with usage.
I would also be interested in a stiffer or adjustable hinge. My lid falls completely open over about a 3-5 minute period. It has been getting progressively worse over time. Otherwise I love the unit
Well wait for a response from Frame work other than a solution form them I would try one of many options.
Can I take apart the bearing? If so I can modify it by distorting the inner part. OR if not
I could drill into the outer part and add a grub screw. In which case the screw would be nylon so as to be replaceable and not wear the inner bearing. Or a SS screw with plastic at the bottom.
a small hole to inject a drying oil like boiled linseed.
An updated hinge has been released and can be ordered from here: Framework | Hinge Kit
This post mentions there was a defective run of hinges. If you have one, you can send Framework a video showing the bad hinge performance and get a free replacement.
