The underbody of my Framework 16 laptop is frequently hot to the touch, especially when I’m gaming, and the air starts to smell of hot plastic. Strangely, my spd5118 sensor shows ALARM (HIGH) temperatures, which appears to be the RAM bus. but the CPU and GPU report being much cooler.
spd5118-i2c-24-50
Adapter: SMBus PIIX4 adapter port 0 at 0b00
temp1: +73.5°C (low = +0.0°C, high = +55.0°C) ALARM (HIGH)
(crit low = +0.0°C, crit = +85.0°C)
No overclocking, no hardware modifications. I just received my laptop last month (May).
Has anyone seen similar issues?
Hardware: AMD Ryzen 7 7840HS CPU with Radeon RX 7700S dGPU. 32 GB RAM in 1 stick.
OS: Bazzite 44 Desktop Edition (kernel 7.0.9-ogc3.2.fc44.x86_64)
BIOS: 4.04
Notice how the spd5118 RAM bus and mt7921 WiFi sensors are the hottest while playing No Man’s Sky at max graphics settings:
cros_ec-isa-0000
Adapter: ISA adapter
fan1: 2391 RPM
fan2: 2368 RPM
ambient_f75303@4d: +59.9°C (high = +86.8°C, crit = +86.8°C)
(emerg = +104.8°C)
charger_f75303@4d: +61.9°C (high = +86.8°C, crit = +86.8°C)
(emerg = +104.8°C)
apu_f75303@4d: +62.9°C (high = +86.8°C, crit = +86.8°C)
(emerg = +104.8°C)
cpu@4c: +62.9°C (high = +104.8°C, crit = +104.8°C)
(emerg = +124.8°C)
gpu_amb_f75303@4d: +64.8°C (high = -273.1°C, crit = -273.1°C)
(emerg = -273.1°C)
gpu_vr_f75303@4d: +68.8°C (high = +70.8°C, crit = +96.8°C)
(emerg = +104.8°C)
gpu_vram_f75303@4d: +62.9°C (high = -273.1°C, crit = -273.1°C)
(emerg = -273.1°C)
gpu_temp@40: +58.9°C (high = +86.8°C, crit = +104.8°C)
(emerg = +107.8°C)
amdgpu-pci-0300
Adapter: PCI adapter
vddgfx: 18.00 mV
fan1: 0 RPM (min = 0 RPM, max = 4900 RPM)
edge: +59.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
junction: +59.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
mem: +62.0°C (crit = +105.0°C, hyst = -273.1°C)
(emerg = +110.0°C)
PPT: 1000.00 mW (cap = 100.00 W)
mt7921_phy0-pci-0400
temp1: +74.0°C
ucsi_source_psy_USBC000:003-isa-0000
in0: 0.00 V (min = +0.00 V, max = +0.00 V)
curr1: 0.00 A (max = +0.00 A)
k10temp-pci-00c3
Tctl: +63.4°C
ucsi_source_psy_USBC000:001-isa-0000
BAT1-acpi-0
Adapter: ACPI interface
in0: 16.48 V
curr1: 0.00 A
amdgpu-pci-c400
vddgfx: 1.29 V
vddnb: 760.00 mV
edge: +58.0°C
PPT: 33.09 W (avg = 30.11 W)
spd5118-i2c-24-50
ucsi_source_psy_USBC000:004-isa-0000
in0: 5.00 V (min = +5.00 V, max = +20.00 V)
curr1: 5.00 A (max = +5.00 A)
framework_laptop-isa-0000
fan1: 2391 RPM
fan2: 2368 RPM
ucsi_source_psy_USBC000:002-isa-0000
nvme-pci-0500
Composite: +50.9°C (low = -40.1°C, high = +89.8°C)
(crit = +93.8°C)
Sensor 1: +54.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +52.9°C (low = -273.1°C, high = +65261.8°C)
acpitz-acpi-0
temp1: +59.8°C
temp2: +61.8°C
temp3: +62.8°C
temp4: +62.8°C
temp5: +64.8°C
temp6: +68.8°C
temp7: +62.8°C
temp8: +58.8°C
