Hotspot fails due to bad channel (firmware for ax210)?
Fedora Workstation
Which release version?
45
Which kernel are you using?
Linux 7.2.15-300.fc45.x86_64
0.0.3.20
When I start my hotspot in GNOME Settings, no other devices can see it. With advice from an LLM, I attempted to troubleshoot. From the output of iw dev, it seemed like it was using channel 13 for 2.4 Ghz (band was set to auto), which the LLM told me does not match US regulations. If I switched the channel or forced 5 Ghz, the hotspot would be visible to the other devices again.
It also had me check the latptop was set to the US regulations with iw reg get, and suggested it could be a bios or firmware issue.
This was not a problem in the past, so it was potentially a recent regression.
I am surprised you can let it do channel 13. I wasnt able to do that even if I tried.
Also it depend on device, I think – pretty much all radios are capable of sending and receiving on channel 13.
What region was it set to before all of that?
I didn’t change the channel. If I delete the hotspot and open gnome settings to reenable it, it automatically uses the bad channel. From the LLM and terminal output, I am pretty sure it is set to US regulations but the firmware is still enabling channel 13.
I filed a report to the redhat bugzilla with logs here: 2566290 – Firmware for AX210 Network Card Does Not Use Legal 2.4GHz channel for Wi-Fi hotspot
