My laptop becomes quite hot even when I’m not running demanding software. The fan also becomes noticeably louder. What are the common reasons for laptop overheating, and what steps can I take to reduce the temperature?
Welcome to the community! I think one of the big reasons of a laptop getting hotter and the fans spinning faster would be dust buildup. It’s quite easy to take apart the FW 12 and blow the dust off the fan and heatsink fins. Or at least check to make sure they aren’t coated/plugged up.
If it isn’t a dust issue, it could be something like some kind of software running in the background that’s eating up processing power, or possibly even an issue with the thermal compound on the machine, or something along those lines.
Those are just some general thoughts. If you can provide some additional info about your machine, OS, and use case, people may be able to chime in with other idea and suggestions.
Consider running uptime on the console, and pasting the text output here. The three numbers on the right are your system load, and if they are very high, it means something is snaffling your CPU even if you think it is not running anything.
The above will work on Linux. If you have Windows, a screenshot of a CPU performance graph will do.
First thing to do is install software to monitor temperatures and CPU speed (for example hwinfo64). That way, you can determine whether the machine is actually overheating (I.e. CPU at 100°c and clock speeds below what they should be), or simply running as intended.
If you’ve noticed this issue getting worse over time despite running the same programs with the same power usage settings, then yes, it may be due to dust buildup.
