How to increase display timeout on Framework 12 using Bluefin Linux
my screen times out too quickly and I haven;t been able to figure out how to keep it from timing out so fast. Any suggestions?
Thanks!
Usually a Settings dialogue box in a Linux distro will have a search feature. If you have one of those, try searching for “screen” or “screensaver” etc.
I’m on Fedora, but using GNOME which should(?) be the same as your system. Does this help?
Also:
Thank you
Thank you so much, I hadn’t been able to find those screens before (Linux newbie here, big time) but I hadn’t noticed the second tab for “power saving” under which the options were listed. Just changed the timeouts for battery and plugged in. (breathing sigh of relief).
