How to make the polarized 13 Pro screen work with sunglasses?
I’ve had my 13 Pro for a few weeks and am just now traveling with it for the first time. Much to my disappointment, I’ve discovered that the screen is polarized in a way that makes it look completely black when viewed through my sunglasses (necessary outside due to a light sensitivity).
This is a real bummer, and basically makes my awesome new laptop unusable outside. I’ve seen this happen with cheap store displays and menu boards, but I was very surprised to find out this was a problem with the 13 Pro too.
Anyone have any ideas for a solution (other than “get rid of the sunglasses”)?
I’m not a physicist, but wouldn’t it be the glasses that are polarised, rather than the screen? If so, I wonder if you could get a pair of glasses that don’t have this effect. I happen to have within reach some cyclist glasses with a yellow night-driving tint, and I expect they have a UV filter; with those on, my 13 Pro screen is still perfectly visible. For clarity, I am not recommending night-driving glasses, just observing that some glasses are fine with the Pro’s screen.
However, as another solution, I assume you have the new matt touch-screen. The old 13 screen is backwards compatible with the Pro, and if you buy that you’d lose the touch feature. I don’t know if it would work with your sunglasses, but if you would be willing to go in this direction, log a call with Support to see if the 30 day returns window if fine even if you install it and it doesn’t work for you.
Thank you for your thoughts! I’m not a physicist either, but I’ve had this issue long enough to know that the problem is they’re polarized in opposite directions - the screen is emitting light that’s polarized in the direction the sunglasses are designed to filter.
You’re right, I can look for other sunglasses options, but I’m hoping there’s some other solution - reverting to the non-touch screen from the regular 13, or some kind of re-polarization filter or something.
No worries. My reading of the product I linked to, at least for the UK supply, is that the 2.2K screen is also matt, and the 2.8K may not be. I don’t know if that has an effect on polarisation, but perhaps Support can give advice on that too.
Here is a thought… I know that pilots have to deal with that exact issue you have with the consul they use and they way they deal with it is to buy none polarized sunglasses… I think sunglasses are built in a way to reduce reflections of water so all polarized sunglasses will give you that problem. but you are right to complain about it as some phones have screens that doesn’t have problem with polarized sunglasses and some do…
Unfortunately there’s not a lot of options except “change sunglasses” while using the laptop, this is inherent with the technology, IPS screens uses linear polarization by design, most OLED screen use circular polarization.
If you have the issue with glasses, I assume F13 pro screen uses IPS technology, you can validate it if the screen is brighter when you tilt your head. I’m not sure it exist with glasses, but circular polarizer (instead of linear) in the glasses should limit the effect.
I had the same issue with polarized glasses while driving a car with polarized screens in dashboard, with your dashboard all black you have no other option than changing glasses for driving.
The simplest option is to not use polarized sunglasses but that’s not really a solution.
An instant solution is tilting your head or rotating the laptop but that’s not comfortable.
A pretty good option is to use a circular polarizer film or waveplate film on top of your screen so that your sunglasses’ polarizer doesn’t block all light from the screen.
A costly option is to replace the screen with an original or matte, but that’s not really an easy fix
Tell us what you end up doing in the end!
That’s really interesting topic - I didn’t know about that difference between IPS and OLED screens.
There is even more interesting thing: I tested my polarizing sunglasses on different screens and results are really surprising:
On Dell IPS screen and LG IPS screen both are clear and readable, but they are completely black when I turn my sunglasses by 90 degrees (left or right). On the other hand my very old Samsung IPS screen - more or less readable, but completely black when I turn sunglasses by 45 degrees. And I confirm - FW 13 Pro is completely black in normal sunglasses position, but clear and readable when turn by 90 degrees.
That all means different manufacturers of different IPS screen have this linear polarization mounted with different angles :slight_smile:
And indeed - my iPhone screen (OLED) has no issues with this sunglasses - screen readable in all angles - I guess due to circular polarization :slight_smile:
If you’re interested in the topic, there are a few interesting technical articles.
I also saw that iPhones use different technology than circular polarizer for anti-reflective treatment, but not sure how it is done.
https://optics.ansys.com/hc/en-us/articles/5845197523731-Antireflective-circular-polarizers-in-OLED-display
Get differently polarized sunglasses? (Or just look at it sideways XD)
LCD displays work using polarization with the liquid crystals twisting or not twisting the polarization and then passing through a filter.
The resulting polarisazion depends on how the screen is manufactured and how the displays are cut up.
Oled does not use polarization at all for it’s functionality but there are also no oled options available so that is out.
I have had the same problem with the plasma screens on the heating controls and radio in my car. Had me very confused when I first saw it happen, until I took my sunglasses off.
You sure those were plasma? Didn’t know plasma display were polarized but to be fair they kinda died out before I got interested in displays.
Well, it is a 2013 European Ford Mondeo. The displays are fixed characters, not LCD screens, and have the reddish colour of single colour plasma displays. I’m pretty sure they are not LED displays.
The drivers console has an LCD screen, I can’t recall if that gave me the same problem.
LCD has nothing to do with the shape of the segments, what you mean is if it is a segment or a matrix display which can both be made with various technologies. I am sure you have seen a calculator display before, those are usually individual segment lcds.
Given the age and that it is in a car it is much more likely to be lcd than plasma or vacuum florescent since both of those technologies are way more expensive and not really produced anymore.
LCD will have issue at some orientations with polarized glasses, question is just how it was manufactured, if you tilt your head you’ll likely have one disappear while the other becomes visible.
I have a car with a heads up display. My speed, the speed limit etc. is reflected on the windshield. With ordinary sunglasses this heads up display vanishes. I had to buy non polarized sunglasses for driving. These sunglasses are still dark, they still have UV protection, but no polarization. They should work for you.
Hugh
You can place a rotating polarizing film over the screen to change the screen polarization.
Simple experiment:
place a linear polarised sheet between the screen and your sunglasses, and rotate the sheet 45 degrees. See what happens while wearing sunglasses.
Don’t ask me why it works, its a quantum physics effect.
