In the body of your post, please include those following details.
- Which OS (Operating System)?
- Which release of your OS (Operating System)? Fedora Workstation 37 kde spin
- Framework laptop 12th generation i7 1280p
Hello all, I am attempting to create a windows virtual machine and route the right side bank of thunderbolt 4 ports directly into the virtual machine. it will house my egpu so I’m hoping for like native performance but still keep linux as my primary OS. Unfortunately I am not that familiar with Virtual Machine Manager and how to do this.
I suppose the first question I need to confirm is what is the pci device id that controls the right side thunderbolt 4 ports? I think it must be one of these three:
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 02) (prog-if 00 [Normal decode])
Subsystem: Device f111:0002
Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 3
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: 7a300000-7a3fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Capabilities: <access denied>
Kernel driver in use: pcieport
00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 4
Bus: primary=00, secondary=02, subordinate=2c, sec-latency=0
I/O behind bridge: 3000-3fff [size=4K] [16-bit]
Memory behind bridge: 52000000-5e2fffff [size=195M] [32-bit]
Prefetchable memory behind bridge: 6000000000-602fffffff [size=768M] [32-bit]
00:07.1 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 5
Bus: primary=00, secondary=2d, subordinate=55, sec-latency=0
I/O behind bridge: 5000-5fff [size=4K] [16-bit]
Memory behind bridge: 7c000000-881fffff [size=194M] [32-bit]
Prefetchable memory behind bridge: 6030000000-604bffffff [size=448M] [32-bit]
I’ve done quite a bit of trial and error following this guide:
specifically for these two commands:
virsh nodedev-list --tree
virsh nodedev-dettach pci_
but without success… so i’d like to take a step back and see if you all can help me positively identify the pcie device id to start with. I know the general steps I need to follow are the following:
add the pci device to a blacklist so it doesn’t get loaded on boot
assign to a virtual machine
boot up
Your help is much appreciated =) I’m very excited to play diablo 4 but am having trouble with crashes during lutris.
