Excuse the questions from non technical person here.
My surface 4 doesn’t start up anymore, don’t know why. Can I take all of the components SSD/RAM etc and put in the framework laptop?
This should be no problem unless the reason for you surface not to start up was because of a broken SSD/RAM. Then your Framework laptop wouldn’t start either.
The RAM on the Pro 4 is soldered to the motherboard, but the SSD is a 2280 M.2 NVMe drive so it should work in the Framework.
