I thought I’d had enough for the last year of monitoring the battery wear but what is happening is clearly of interest.
After some 3 months of a lot of use unplugged and once I had discovered that I could ‘read’ the wear and the BIOS update that permitted the ‘reading’ of cycles I took a devoted interest.
a) I started to use the laptop plugged in >90% of the time and b) set the Battery Charge Limit (BCL) to 78%. This seemed not only to stop the recorded wear rise that had reached some 7% after four months but it started to decline.
As it started to decline I thought either the computer was reading wrong or what. I have since discovered that the battery pushes the info to the OS and the OS does very little. So I thought maybe the battery itself could do with reset.
So approx each month I reset the battery by running it down until the laptop automatically turned off and then charged it to 100%. Coincidently with that each time the recorded wear dropped. I know it’s a bir uncanny.
Now 13 months later I thought time for a change so I decided to lower the BCL to 69% This was due to the fact that at 78% the battery was till charging to nearly 4.165V which I can understand may wear the battery. So now I have the battery at 4.032 with the BCL at 69%
I was expecting a change but not the one I have. Today I did what was to the be the last of this routine checking on 31st March and what happened . . .
The wear has just recorded 2.8% 2.7% which is lower than it was upon receipt.
So either
- The reading is wrong now and there is a lot more wear or
- The reading is correct and the previous reading are way out.
The take is this.
If measurements are not taken over a long period with different settings and use patterns, and tabulated and graphed there is no easy was to see what is/maybe happening. Here is the graph from 4th Jan 2023 to 30th June 2023.
Each day I take multiple readings and the figures on the graph are the lowest for each day. To see the actual data that I take it from see the monthly data
http://217.155.51.23/newdevices/framework/battery/apr23.php . . . etc.
Graph of data since receipt in Feb 2022
UPDATE 5th April: Since lowering the BCL to 69% the ‘wear’ has been consistently lower, between 2.6% each morning and a max of 3.0% late evening.
Screenshot of HWInfo on 9th April 2023, after 13 months ~ no joke.
UPDATE 19th April: Since I inadvertently let the charge drop a bit I used the opportunity to reset the calibration by a full discharge > a full recharge and then > discharge to my ‘new standard’ of 66%
The cycles went up 2 which I wasn’t expecting and the wear sort of doubled in that in went from 2.6 to 4.8 ???
