I dont like the audio jack gone
@anon81945988 I used suspend as an example but the power drain occurs regardless. Normally, when no display is connected to an Displayport or whatever port you choose, the controller for that port goes into a low-power state waiting to wake up when you plug something in. As far as the Thunderbolt port is concerned, something is plugged in, the expansion card. Thus it is kept in it’s high-power/active state at all times. I choose poorly in explaining that before, my bad. Since the USBC cards are dumb and contain no circuitry themselves, they alone are immune from this condition.
@anon81945988 Not at all, this is fine. I think that any expansion card, absent any tricks like the HDMI card, will consume more power than the equivalent function being built into the board. This will occur purely for the same reason as above, an inability to move to a low-power state when not actively used. If the DAC is on the motherboard then it can move to this low-power state.
Unless they have improved the design where the expansion cards are no longer straight converting signals and communicating with the motherboard. As it stands now, they simply convert signals although I suppose some minor amount of communication must occur to ensure that conversion occurs properly. I think the DAC and the detection of if something is plugged in will all be on the expansion card.
I won’t claim to be an expert, I’m just regurgitating what I’ve read from various threads on the forum and from Framework employees on the matter. I don’t know how they could make the expansion cards smarter and I imagine, if they could, they would have created a Mark II version of all problematic expansion cards.
Small error, it isn’t HDMI, it is the DisplayPort cards that have a workaround. I’ll update my above posts now.
I wonder how feasible it would be to get a USB+headphone jack module. Like Dual USB-C Expansion Card - #320 by tbe, but with x1 USB-A and x1 3.5mm. Or a USB-C and 3.5mm.
3.5mm jack is literally the most reliable part in a smartphone. Buy a Shiftphone or Pinephone instead of a Fairphone
The jack in the FW13 is also very easily replaceable. The bad audio is due to downward-firing speakers instead of DAC. Also the headphone jack in the FW13 seems to use a single DAC from the speaker, as the speaker seems to be mechanically disconnected when you plug in your headphone (the OS claim that the speakers are unplugged), so more energy saving. AFAIK expansion cars other than USB consumes more power. I have another computer that has built-in HDMI, SD card slot and VGA that has lower power consumption compared to my FW13 with a microSD and HDMI expansion cards installed.
This is so backwards, it’s objectively safer to have physical buttons on cars, people are pushing back, some car manufactures are returning to physical buttons are some legislations are under way.
The audio expansion card is a bit expensive though.
Unfortunately there are many sheeples that get pushed around too easily. People still buying iphones after “batterygate” (apple intentionally reduce performance and battery life on older phones via OS updates to push users into buying newer ones)
Yeah, that’s not what that was, try again
Apple claimed that they reduced the power consumption of the processor to preserved the battery. However according to user experiences, both the performance and the battery runtime worsened after the update
No, they reduced the power consumption to stop the phone hard resetting itself when it tried to draw too much power.
If you’re going to pick that fight, at least get your facts right.
That may be so but your conclusion still does not make sense. iPhones start shutting down with high power draw on worn batteries, Apple pushes out a fix that limits performance to eliminate said high power draw. Event A led to Event B, there is clear causality. What you are stating is that Event B (nerfing performance) was caused by Event C (Apple wanting to sell more iPhones), completely leaving out Event A (Aging batteries cause unexpected shutdowns).
If the sole goal is to make new iPhones look better, it would make more sense to sandbag performance from the very beginning. You are arguing for a conspiracy that doesn’t exist. Even the article I linked to doesn’t argue what you are suggesting and nobody would accuse iFixIt of being an Apple apologist.
I’m not even taking a stance on Apple’s actions, just pointing out that it does not make logical sense what you are suggesting and no credible outlet has ever suggested the same as you that I’ve seen.
This is getting off-topic and more than a bit heated.
Actually since the thread has run its course, it’s best just to close it.
