Excess loctite compound on the screws. This can make fasteners very hard to tighten. This is very common with lots of fasteners on lots of products to have excess loctite. Clean it off and see if that fixes it. Can put your own blue loctite on if you want.
Misalignment when tightening meaning cross threading meaning you need to retap the threads.
Bad threads ine heat sink.
All fan screws are 6-32 screws the length can vary, Framework specs 27.3mm with a smooth shaft rather than fully threaded. But being fully threaded doesn’t matter. You should be able to find some at a local hardware store that has fasteners, you might need to cut to length.
And the loctite track might be the issue. I checked with my wife, who handles a lot of mechanic at her work, and her guess is that threadlocker has somehow dried, and is blocking the screw. And indeed, the screws are blocking with a hard stop when they reach the blue threadlocker
I quickly tried to remove a bit of it with alcohol, but to no avails.
It does not look “normal”, and I don’t want to break something, I’ll try to contact the support to see if there is any know way to handle this.
If you are certain that the loctite is the issue, you might see if you could melt it (soldering iron, for instance) and wipe it off the screw while hot.
No 100% sure, but that’s a great idea to remove it, never though about this path. Slightly worried to melt a tiny bit the threading though, as it is really small, but I note the idea, thanks a lot for sharing it.
I just sent a support ticket to see if there is an obvious solution, but I note all your ideas if indeed, getting rid of the loctite is the next thing to try.
The fan should fall in place, If you have to apply any force to push it in place, it moves the pins enough to make one screw out of 4 impossible to drive in.
Try the screws without the fan, if they are ok then you need to widen the bottom 4 holes on the noctua fan until it falls on the pins effortlessly.
Ok, so the screw loctite hypothesis is largely confirming.
My wife brought M3 screws from her work to test, with approximately the good length, unfortunately a bit short to be used “in production” (and as you suggest EU47, I’ll try to find the exact length from a local hardware store), as well as a spacer with the matching threading.
The spare M3 screw are going fine inside the dissipater pins, which was a relief: I feared that your guess, Attila_Antal, could be exactly the issue, as indeed I had to try a lot of time with various angles to fit the Noctua on the dissipator (and also as I read that your tip, widening the hole of the Noctua, was the solution for many other people).
And the huge hint/confirmation: when I tried to use the screws I received with the Framework and the fan inside the spacer she brought, they blocked … at exactly the same position, just when the loctice reaches the spacer threading !
So indeed, a huge hint toward the dried/defectuous loctice.
I have to admit I’m quite relieved that it is (probably) on this side, not on the dissipater
I’ll try to find screws with the exact required length (I’m missing 1mm or 2 right now), and I’ll share here if it works and solves the issue (or if I have other tips from the support).
Thanks a lot for your help and ideas, that is invaluable, and confirms that I made a good choice with the Framework, as the community was one huge drive into selecting this one
