Which release version?
September 9th, 2026
Which kernel are you using?
7.2.3-1-cachyos
04.02
AMD Ryzen AI 300 Series
The microphone shows up fine on arecord but whenever I try to use it, it doesn’t make any sound. I’ve also tried toggling the hardware switch multiple times. Has anyone else had this issue?
Could you show us a screengrab or short video of your OS sound settings? I don’t know Cachy OS, but in the dialogue boxes I’m used to from Mint or Ubuntu, there is an Input tab in the Sound dialogue box. Often one has to choose from several devices, and they don’t all work.
I assume Cachy uses PipeWire with WirePlumber? If so, the Audio > Sources, Audio > Filters, and Settings sections of wpctl status will also have useful info.
