Internet connection stops working after ~10 seconds
I own a Framework 16 laptop running Fedora 42, KDE 6.4.3, Kernel 6.15.7-200.fc42.x86_64, BIOS 3.05.
There is one specific network which drops the internet connection a few seconds after connecting. This applies to both, a wired and a wireless connection. I am out of ideas to try.
Facts I collected so far:
  • this network works perfectly fine on the same machine running Windows 11 (both wired and wireless)
  • other devices have no issues connecting to this network whatsoever
  • this device has no issues connecting to other networks
  • pinging e.g. google.com fails ~10 seconds after connecting
  • pinging e.g. 8.8.8.8 fails ~10 seconds after connecting
  • pinging local addresses does not fail at any point
  • sudo ip neigh flush all does not help
  • sudo systemctl restart NetworkManager makes it work for another ~10 seconds
  • sudo ip route flush table main does not help
  • journalctl -f shows NetworkManager-dispatcher.service: Deactivated successfully. and SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' when internet stops working
  • sudo dmesg -wH does not show anything at the time the internet connection drops
  • setting a static IP does not help
  • deactivating wifi completely and just using a wired connection does not help
  • deactivating the firewall with sudo systemctl stop firewalld does not help
  • setting sudo nmcli general logging level TRACE domains ALL reveals the following journalctl messages around the connectivity drop
journalctl trace log
Jul 23 09:33:33 fedora NetworkManager[69324]: [1753256013.7261] device[[redacted device id]] (eth0): queued link change for ifindex 2
Jul 23 09:33:33 fedora NetworkManager[69324]: [1753256013.7261] l3cfg[6e5bc348764d75a1,ifindex=2]: emit signal (platform-change-on-idle, obj-type-flags=0x2)
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7259] device[[redacted device id]] (eth0): stats: refresh 2
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7260] platform-linux: do-request-link: 2
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7261] platform-linux: event-notification: RTM_NEWLINK, flags 0, seq 459: 2: eth0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? not-init addrgenmode none addr [redacted MAC] permaddr [redacted MAC] brd FF:FF:FF:FF:FF:FF tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:32661,7227917 tx:10909,3203257
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7261] platform: (eth0) signal: link changed: 2: eth0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? init addrgenmode none addr [redacted MAC] permaddr [redacted MAC] brd FF:FF:FF:FF:FF:FF driver cdc_ncm tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:32661,7227917 tx:10909,3203257
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7261] l3cfg[6e5bc348764d75a1,ifindex=2]: emit signal (platform-change, obj-type=link, change=changed, obj=2: eth0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? init addrgenmode none addr [redacted MAC] permaddr [redacted MAC] brd FF:FF:FF:FF:FF:FF driver cdc_ncm tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:32661,7227917 tx:10909,3203257)
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7261] device[[redacted device id]] (eth0): queued link change for ifindex 2
Jul 23 09:33:35 fedora NetworkManager[69324]: [1753256015.7262] l3cfg[6e5bc348764d75a1,ifindex=2]: emit signal (platform-change-on-idle, obj-type-flags=0x2)
Jul 23 09:33:35 fedora systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jul 23 09:33:35 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=success’
Jul 23 09:33:37 fedora NetworkManager[69324]: [1753256017.7261] device[[redacted device id]] (eth0): stats: refresh 2
Jul 23 09:33:37 fedora NetworkManager[69324]: [1753256017.7262] platform-linux: do-request-link: 2
Jul 23 09:33:37 fedora NetworkManager[69324]: [1753256017.7263] platform-linux: event-notification: RTM_NEWLINK, flags 0, seq 460: 2: eth0 <UP,LOWER_UP;broadcast,multicast,up,running,lowerup> mtu 1500 arp 1 ethernet? not-init addrgenmode none addr [redacted MAC] permaddr [redacted MAC] brd FF:FF:FF:FF:FF:FF tx-queue-len 1000 gso-max-size 65536 gso-max-segs 65535 gro-max-size 65536 rx:32736,7255766 tx:10975,3232282
Welcome to the forums!
I don’t have any answers for you, only a few observations.
Since this ONLY happens on a single network, there’s clearly something different about that network, either its hardware or its configuration. Determining exactly what that is would probably point directly to a solution.
Since both named systems and IP addresses are failing after ten seconds, it’s definitely not a DNS problem. And since you can still ping local addresses, it seems to be a routing issue.
I have (a very small amount of) experience with routing problems under Linux. Can you provide the output of ip route show, preferably both before and after the ten-second mark?
Thank you for your suggestion & sorry for the late response, but I was not in reach of this network since I wrote my post.
Now I am back in reach & currently connected to it without any problems.
Next time I’m encountering issues I will record the routes before and after the connection loss - I am pretty sure it will happen again soon! I don’t want to jinx it, but I had happy times of no connection loss before already :slight_smile:
The connection broke again.
There is no difference in ip route show before and after the connection loss.
default via 172.20.0.1 dev eth0 proto dhcp src 172.20.0.234 metric 100
default via 172.20.0.1 dev wlp4s0 proto dhcp src 172.20.0.103 metric 600
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-9c919db98ec8 proto kernel scope link src 172.18.0.1
172.19.0.0/16 dev br-7414dc282dce proto kernel scope link src 172.19.0.1 linkdown
172.20.0.0/24 dev eth0 proto kernel scope link src 172.20.0.234 metric 100
172.20.0.0/24 dev wlp4s0 proto kernel scope link src 172.20.0.103 metric 600
172.20.0.0/16 dev br-ec21472f9828 proto kernel scope link src 172.20.0.1 linkdown
172.21.0.0/16 dev br-56d907d4a2c2 proto kernel scope link src 172.21.0.1 linkdown
172.22.0.0/16 dev br-d98757f6ec13 proto kernel scope link src 172.22.0.1 linkdown
172.23.0.0/16 dev br-31a7baed5ea8 proto kernel scope link src 172.23.0.1 linkdown
172.24.0.0/16 dev br-5eb8065eddaf proto kernel scope link src 172.24.0.1
172.25.0.0/16 dev br-843380b00d30 proto kernel scope link src 172.25.0.1 linkdown
Huh. And all of those linkdown indicators appear both in the first ten seconds and after it? That’s the only oddity that I can identify in that report.
Yes, unfortunately.
As far as I can tell, the problem isn’t in your setup, it’s upstream of you. Maybe at 172.20.0.1, maybe upstream of that address. I assume you don’t own the router at that address; maybe the owner/operator of it would be willing to troubleshoot the problem with you?
I can finally easily reproduce the error. This only happens on the particular network mentioned above, and only when using Linux.
The internet connection drops reliably after opening the Pycharm IDE. It will not recover from this - restarting NetworkManager makes the connection work for ~10 seconds, but the issue is fully resolved only after rebooting the machine.
As soon as I open Pycharm the internet connection reliably breaks every single time.
This does not seem to be an upstream issue after all, but a weird problem between Fedora, this connection and Pycharm.
I will further go in this direction and contact Pycharm/Jetbrains support on this matter, but given the obscurity of this I don’t expect much from them.
Either way I will update this thread for reference for poor people experiencing the same issue (unlikely, but possible :slight_smile: )
Solution
Found the solution without contacting Pycharm support after all.
The issue was also not Pycharm-specific per se.
Problem
Pycharm triggers the Docker daemon after init if the Docker plugin is set up.
The Docker daemon creates network bridges automatically, starting with 172.0.x.x, until it hits an “available” range. Unfortunately, Docker doesn’t check if these ranges are used by any physical networks. In my case Docker always hit 172.20.x.x, which is the actual IP range of the network in use. This made all internet traffic route to the Docker bridge instead of the internet - hence the connectivity issues. Why it works for 10 seconds - no clue, probably some kind of race condition.
Solution
Remove the (docker bridge) network shown with
ip route show | grep 172.20
In my case this showed
172.20.0.0/16 dev br-cc5389a2bb89 proto kernel scope link src 172.20.0.1 linkdown
hence I ran the following to remove the bridge from Docker:
docker network rm cc5389a2bb89
Then I configured Docker to not use 172.20.x.x anymore:
sudo mkdir -p /etc/docker
sudo tee /etc/docker/daemon.json << EOF
  "bip": "172.25.0.1/16",
  "default-address-pools": [
      "base": "172.25.0.0/12",
      "size": 24
EOF
No network issues occured since then :tada:
That would do it! :laughing: Nice detective work!
