Hi,
I am using the Framework Laptop 12 with the Penoval USI 2.0 stylus. And I ran into an issue :
Palm rejection only activates when the stylus is close enough to the screen to be tracked, and I find this tracking range to be quite small (my palm usually touches the screen before the stylus is detected, which is quite uncomfortable).
Is it possible to configure this tracking range ? I’m would be glad if someone had a solution that works on Linux (NixOS) + Hyprland, but at this point I’d like any information you might have on the topic. I literally found nothing on the internet (I’m wondering if the hardware even allows to configure this range).
I’m also open to any solution, to deal with the palm detection part of the problem.
