Is MOK just a part of running Linux Mint on a Framework?
  • Linux Mint 22.1
  • Laptop 16 AMD 4070 Series
I’m switching from Fedora to Mint, and after installation, it popped up with MOK management. A quick search online said this had to do with secure boot, which I don’t really care about having enabled (or at least, I don’t think I need to care about it). During the installation, it forced this however in order to install multimedia codecs.
Is this just a part of running Mint on the Framework 16? Is there a way to prevent this but still get the multimedia codecs? I’d much rather use Mint over Ubuntu personally.
To me it seems like it should be a thing on all devices with Secure Boot enabled, not just Framework laptops and not just Linux Mint.
Somebody over at reddit asked kinda the same question: Reddit - The heart of the internet
This thread could provide some more insights if wanted:
https://forums.linuxmint.com/viewtopic.php?t=376059
I haven’t needed to deal with MOK (Machine Owner’s Key) myself yet, but from what I’ve read, it doesn’t seem like a problem. Nothing even worth trying to prevent or avoid. Did it mention that the password you set will only be needed once, then will essentially be disposed of? It’s more of a confirmation code than a password.
The only problem seems to be the failure of it, at least explaining that it’s just a one-time confirmation after install, and that whatever password you choose will be asked for only once ever. As I understand it, if MOK is ever triggered again, like installing a different OS, you’ll be asked to again create a confirmation password, for that new one-time use. So it literally doesn’t matter. Use your first name, use 1234567890, makes no difference, as there is no need to remember it beyond that install.
The purpose appears to be to prevent an automated process from trying to make a change the user did not initiate. I presume such as a virus trying to embed a rootkit.
unix.stackexchange.com/questions/679695/security-boot-and-mok-password/679717
From what I’ve read, it’s not specific to Linux Mint at all. The multimedia codecs Mint is installing just happens to trigger it on the Framework. It’s the Framework’s UEFI/BIOS firmware that is causing the MOK (Machine Owner’s Key) confirmation to be asked for.
forums.linuxmint.com/viewtopic.php?p=2192072
