I just got my framework 13 pro diy from batch 12. I unboxed it and went through the guide. When putting the top input cover on, I noticed the cables going to the display got pinched. And the magnets weren’t able to hold the top right. I know there’s the pin in the bottom, but this was obviously the cables. I tried to somehow route the cables better, but it didn’t seem to make a difference.
Yeah this situation is not the bezel sitting flush however there were a number of others who posted photos of their before and after I believe that might make sense of where things are suppose to route.
It is a tight fit for sure, cables being pinched over a long period of time especially at a point that moves can be an issue later on. Some of the routing takes some patience and coaxing to get things to lay just right…“stay…nope it moved again a little…stay…ok good!”
I think the consensus is “fiddle it gently into position”, both here and on the other thread. But I think reaching out to Support, if you’re having trouble, is a very good idea.
