My cat likes to walk across and sleep on my RGB keyboard.
When she does she often changes the color/brightness/animation settings.
Is there a way to disable these keyboard settings and re-enable them when I actually want to make a change?
Or is there a simple way to restore the settings to a specific/saved setting?
You could move the keys to a place that she’s less likely to step on using Via, the configurator GUI located at keyboard.frame.work.
There is also an option to backup your current keymap / key arrangement. I would suggest saving it before making changes.
