Issue setting up Logitech wireless mouse
Ubuntu
Which release version?
25.10
Which kernel are you using?
Linux 6.17.0-6-generic
3.04
AMD Ryzen™ AI 300 Series
I have a wireless mouse (Logitech M185) which is properly detected, but denied. How do I enable the mouse?
  • the same mouse and dongle works on a Dell +Ubuntu 22.04 system
  • the same USB port works with a Logitech mouse with a cable
Logs:
~$ cat /proc/bus/input/devices
I: Bus=0003 Vendor=046d Product=c542 Version=0111
N: Name=“Logitech Wireless Receiver Mouse”
P: Phys=usb-0000:c3:00.3-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1:1.0/0003:046D:C542.0008/input/input17
U: Uniq=
H: Handlers=mouse0 event4
B: PROP=0
B: EV=17
B: KEY=1f0000 0 0 0 0
B: REL=903
B: MSC=10
$ sudo cat /dev/input/event4
nothing
disconnect wired mouse and connect wireless mouse:
[10332.622783] usb 5-1: USB disconnect, device number 3
[10338.858038] usb 5-1: new full-speed USB device number 4 using xhci_hcd
[10339.008308] usb 5-1: New USB device found, idVendor=046d, idProduct=c542, bcdDevice= 3.03
[10339.008319] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10339.008321] usb 5-1: Product: Wireless Receiver
[10339.008323] usb 5-1: Manufacturer: Logitech
[10339.024741] input: Logitech Wireless Receiver Mouse as /devices/pci0000:00/0000:00:08.3/0000:c3:00.3/usb5/5-1/5-1:1.0/0003:046D:C542.0008/input/input17
[10339.025011] hid-generic 0003:046D:C542.0008: input,hidraw0: USB HID v1.11 Mouse [Logitech Wireless Receiver] on usb-0000:c3:00.3-1/input0
[10552.626997] audit: type=1400 audit(1761919204.781:332): apparmor=“DENIED” operation=“open” class=“file” profile=“snap.firmware-updater.firmware-notifier” name=“/proc/sys/vm/max_map_count” pid=12136 comm=“firmware-notifi” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
solved with:
sudo nano /etc/default/grub
Find the line starting with `GRUB_CMDLINE_LINUX_DEFAULT` and add `iommu=soft`:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash iommu=soft”
