Which Linux distro are you using: 43
Which kernel are you using: 6.18.6
Which BIOS version are you using? 3.09
Which Framework Laptop 13 model are you using? 13th gen intel
When I set my brightness to 100% in chromium (and only chromium) the colors on the monitor get washed due to excess vibrancy. It also seems to only impact the chromium window. I’m also seeing glitches in netflix video playback.
Has anyone seen anything like this?
EDIT: fixed atleast the brightness issue by turning off hardware acceleration (apparently its a chrome bug)
