Issues with Fedora Gnome and USB Ports
I am using Fedora 42 with Gnome on my Framework Laptop 13 (11th gen)
Kernel: Linux 6.17.4-200.fc42.x86_64
Bios:03.22
Often when I am using the laptop on battery I will plug my wireless mouse or phone into a USB port. The device will not be recognized or charge. I remove the USB port and the device. I plug the USB card into the laptop, then plug the device back in. I might do this a few times. I that does not work, then I plug the USB card into a USB port and then plug the device in. Then it might work.
It does not always do this and it did not do it with Windows. I am not sure if it is some kind of power saving mechanism.
Thanks,
Josh
I just installed powertop and saw that these were all set to good. I changed them to bad and will see if that fixes the issues.
Bad Autosuspend for USB device xHCI Host Controller [usb1]
Bad Autosuspend for USB device Goodix Fingerprint USB Device [Goodi
Bad Autosuspend for USB device xHCI Host Controller [usb3]
Bad Autosuspend for USB device xHCI Host Controller [usb4]
Bad Autosuspend for USB device xHCI Host Controller [usb2]
Looking at it, I was having issues with unlocking the laptop with the fingerprint sensor sometimes.
I’m having similar issues, we’re you able to solve this?
I thought I might be having similar issues according to my dmesg
[566497.698708] xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
[566498.930371] xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
[566501.232409] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[566501.402579] xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
[566501.490243] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
[566502.633777] xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
[566503.869795] xhci_hcd 0000:c3:00.0: Refused to change power state from D0 to D3hot
