I’m having issues reaching hardware sleep on my framework laptop with an HX 370, 64GB ram, Archlinux running 6.17.9-arch1-1
modprobes: blacklist ucsi_acpi, options kvm ignore_msrs=1
cmdline: initrd=\amd-ucode.img initrd=\initramfs-linux.img cryptdevice=/dev/nvme0n1p2:root root=/dev/mapper/root rw resume=UUID=48f0c3e0-78ae-4219-9cf1-c921da13f539 amdgpu.dcdebugmask=0x10
I tried with/without the blacklist of the ucsi_acpi, without any modules, with/without the power adapter connected
amd-s2idle: s2idle report created on 2026-01-15 12:48:00.670690 using amd-s2idle 0.2.11 - Pastebin.com
The issue seems to be around ACPI/thunderbolt sleep but I can’t find why this is happening
I’m a bit lost, does anyone solved the same issue ?
