Keyboard and bezel do not sit flush right
Hello guys,
I have issues in setting up my Framework 13 pro.
The keyboard (top right corner) and bezel (bottom right corner) do not flush well. From what I read, it could an issue with the wire. However I fail to understand (and I am a bit afraid of messing up) how it should be moved from the position I have (pictures linked, I can upload more if it’s needed).
Thanks a lot for the people reading this !
I still don’t think this is well explained.. but this is effectively a “community forum” … and not a Framework support forum.
You’d be better opening a ticket directly with Framework support. I believe this is a known situation, so they should have some guidance for you.
I had similar problem. Maybe the gap was smaller than in your case. I checked if it is not squeezing cables. After that I pressed it gently together and tightened screws.
But let us know what the support told you.
Refer to step 11 for the cable routing, specifically the green step, and the user comments. Hope they help. (Yes, you have a Pro, but the cable routing should be very similar if not identical to the 13)
If you look closely at Framework’s 3rd photo, the wifi cables are right at the bottom, touching the chassis. The webcam cable is to the far left in that space. This allows for maximum room available for the power button from the input cover to sit in.
The vertical cross section looks something like this:
Hello ! for a start thanks a lot for the time you took to answer my issue. I tried doing it as you told me (the support said the same thing, so thanks a lot !). I tried arranging the cables a dozen times but it’s even worst than before to be honest. There’s way less space on my laptop than on the picture unfortunately so it’s a bit trickier I feel. And when it’s slightly better, when I try putting the bezel it fucks up the cover. I feel a bit down about the whole thing. Anyway, thanks for your help !
