Hi ![]()
Framework Laptop 16 with a Ryzen 7 7840HS running EndeavourOS here.
I just moved the touchpad to the left and the keyboard is acting strange now. This configuration has worked before and the previous configuration also doesnât work.
The keyboard emits lots of keypresses, could be pressing ctrl or just spamming lots of Ds. Most of what I press on the keyboard doesnât do anything. Sometimes, itâll do something completely different. The touchpad and the numpad work. While the random action is going on, the WiFi adapter will reset a lot until it doesnât come back.
To be able to do anything, I removed the keyboard and attached another one via USB. Sadly, the touchpad doesnât do anything when the keyboard is not installed.
I also noticed the power LED is cycling âoff â orange â blue`.
Because it has been working earlier, Iâm thinking about what I might have done differently and it could be that the laptop wasnât yet completely shut down while I removed the touchpad.
What kind of connection is behind the pogo pins? Have a it shorted something while sliding down the touchpad? Pretty sure the shutdown was complete by the time I put it back in.
Is there any hope of getting it back to work? Luckily, there are replacements parts for everything - I just donât know what to replace..
Thank you for any responses and kind regards!
