Keyboard cleaning gone wrong
Windows OS - Windows 11
Framework 13 AMD 7040 Series
Hi all,
I am experiencing a power issue, and multiple connectors issues with my Framework Laptop 13 after a disassembly for a “quick” “easy” cleaning of the keyboard and touchpad.
Below is a detailed description of what happened:
Earlier today, I opened the laptop to clean it.
-I did not disconnect the battery before starting.
-I first disconnected the main black keyboard/top cover cable. When removing it, the plastic reinforcement tab detached and I had to apply some force to remove the connector.
-After that, I disconnected all other top cover cables (camera, power button, keyboard, touchpad). I removed the touchpad module to inspect it and cleaned the components. I then reassembled everything but initially did not reconnect the internal cables (to continue working and seeing if everything looked ok).
-Later, I disassembled the keyboard section and cleaned the keys individually. I reconnected everything to the top cover assembly and reinstalled it in the laptop.
At that point, the system did not power on.
I disconnected and reconnected the battery, but it still did not power on.
I reattached the plastic reinforcement tab to the keyboard cable and reconnected it.
-After that, the laptop powered on, but the internal keyboard, touchpad, and fingerprint reader were not functioning.
I disconnected the keyboard cable and battery again, and tested multiple configurations. The system was able to boot using an external USB keyboard and mouse.
However, I then started experiencing power instability:
The laptop would immediately power off when unplugging AC.
Windows triggered “Preparing Automatic Repair” after abrupt shutdown.
I was prompted for the Windows recovery key, which I entered successfully.
The battery percentage was decreasing, so I connected AC power, and the system powered off unexpectedly.
After several reconnect attempts (battery and AC), the system became increasingly unstable.
Eventually:
With battery disconnected and AC connected, the LEDs began blinking blue and orange continuously without pressing the power button.
No fan activity.
No display output.
The board remains physically cold.
Reconnecting the battery sometimes results in two red LED blinks.
Pressing the power button produces only a brief blink but no startup.
I have tested minimal configuration (battery, keyboard, and touchpad disconnected) and the behavior remains the same.
The system was booting normally earlier the same day, so this appears to be related to the power subsystem / embedded controller rather than a completely dead motherboard.
Could you please advise on:
The meaning of continuous blue/orange LED blinking on AC only
Whether this indicates an EC or charge controller fault state
Any recommended recovery procedure (or completely giving up and sending it to repair or order new parts and try to fix it)
Thank you
