I decided to take the two framework keyboards apart, clean and re-tin the contacts in an effort to make them more reliable.
I have an ANSI English and a numpad.
In the process of putting them back together, I accidentally swapped the PCB for the two keyboard. As a result, they didnt work.
When I swapped them back, its working immediately.
My only conclusion is that the EC is somehow able to tell what is plugged into which slot. How does it know? Should it know?
Because the two PCB on the two keyboards seems identical.
I bring this up as I have a dead British ISO keyboard. The membrane is completely gone, but the PCB should still be in good condition. If I can turn it into a spare for either of mine, or experiment with other things, that would be great
Could you elaborate on just what you mean, when you say they didn’t work? Like, are you saying that they didn’t even show up? lsusb on linux, or device information on windows.
A FWL16 keyboard and a numpad have different configurations in their firmware. They will not work swapped. But they should still show up on the usb bus.
No input module whatsoever? This is Framework’s warning screen?
I wouldn’t be surprised if it detected them swapped, seeing a numpad instead of a keyboard for example. But I wouldn’t think it would say it sees nothing.
One one the pins tells the EC the size of the input module, using a simple resistor. This is so that it can tell if any spots are open and throw a warning. An open spot would have voltage on the pins with could be accidentally shorted and potentially cause damage.
I think the laptop is able to detect that there are “invalid” things in the slots and refusing to provide power, or that the keyboard firmware was getting power, but seeing the incorrrect signature and was throwing a fit.
It wouldn’t make sense for the keyboard membrane to be incompatible, because it’s the exact same PCB.
Which is why its quite surprising.
You can probably try this out by just putting numpad and keyboard in an “illegal” position. Mayb also try other fun stuff like a numpad + macropad, or two/three of those.
