I use rarely the keyboard, the laptop is normally docked away, with OcuLink external GPU and stuff.
I noticed that the keyboard has started to give issues, perhaps due lack of use. I have to sometimes really bang the keys to get a character.
So, any ideas for curing it? Bath in contact spray maybe?
This should not happen though, sounds to me that the contacts in keys are not gold plated. I mean, this is a very expensive laptop. should not be crap like this.
pretty sure its not the “cable”, I gather the keyboard connects via serial-type interface. So there is no ribbon connector in FW 16, its connected via gold plated pads.
Gotcha. Does that clip out? If so, give it a spray with a compressed-air duster, and see if that helps. Of course, your device should be user-serviceable: although I would expect a keyboard to last longer than two years, it should be trivial to obtain a new one.
What’s your warranty length? Some (Spain I think) are three years, but otherwise they’re one (US) and two (UK and Europe). Not sure about other territories, but it’s worth a check.
