Has anyone else had keys leaving marks on the screen or does it not bother you? Not sure if they are visible with the screen on since I wipe it down regularly now but it’s annoying to do.
I’ve never seen a laptop have that except a thinkpad with the nub which left a permanent mark.
My coworker’s macbook has the keyboard imprinted on his screen too. It’s because he stores it in a backpack that puts pressure on it. If you are storing it in an inadequate case, that doesn’t prevent compression, any modern laptop will have this “problem”.
You are probably using a case that does not protect it properly.
Mine lives in a backpack and within 6 months wore the matte coating away aroynd the corners of keycaps on my screen and created a line where the top of the trackpad module is. It sucks but when I eventually buy a new display (Framework PLEASE give me a vrr oled) ill be keeping a thin microfiber cloth between my keyboard and screen. I was batch 4 so I’ve had mine for a bit over 2 years now
Whenever I’ve tried to search for laptop bags it’s so hard to find anything offering real protection. And it’s just ridiculous if you look at the advertising, a bit of foam being touted as if its high level protection. It’s like some kind of joke.
So, years ago I gave up, and use a 2mm thick aluminum plate placed against the screen side when inside bags. Someone else on the forum got a cut-to-size carbon fiber plate, off ebay iirc. My plate serves dual purpose, when using my laptop on my lap, couch, anywhere that might block the vents, the plate goes underneath. Added adhesive velcro to keep it attached there, and stair grip adhesive sheet to both give it grip when on any surface & protect tables from the possibility of scratches.
Yep.
I actually have a laptop bag which offers real protection. A Dell branded bag from maybe 15 to 20 years ago. Looks like a regular bag, fabric on the outside. But thick hard plastic inside around the edge, laptop held in the middle by very dense foam. I wouldn’t be surprised if my laptop could survive a high fall in that bag.
Haven’t found another bag with as good protection.
