hello!! I just got my Laptop 12 a little over a week ago, and I’ve been having a good time so far …!
I installed Debian 13 when I first got it, but yesterday I installed Fedora 43, which is when I began to notice this issue: when I connect or disconnect the charging cable, the laptop wakes up (even while the lid is closed). I can circumvent this by plugging in the charger before shutting the lid, which will allow it to sleep while charging.
I tried a fix from this thread from 2023, which did disable waking via keyboard input, but connecting or disconnecting the charger still wakes my laptop. I also double-checked the BIOS and confirmed that Power on AC attach is indeed disabled …
anything will help, I think – thank you !!
Software: Fedora 43 + KDE Plasma 6.6.3
Hardware: Laptop 12 + Intel 13th
3 hours later, an update: following the instructions found here, I updated my BIOS to the latest version using fwupdmgr, but the problem remains all the same !
