Laptop 13 Pro AMD (HX 370) no POST, LED 12× green + 0xA3: Kingston KF556S40IBK2-32 with Kingston DRAM chips
Brand new Laptop 13 Pro DIY, AMD Ryzen AI 9 HX 370. No image at all on the internal display or on an external monitor (TS5 Plus dock and HDMI/DP cards).
LED sequence: white, 12× green, orange, then 10100011 (0xA3) followed by 01000111 (0x47).
Already tried:
  • waited 30+ min for memory training, on dock power
  • one stick at a time, in both slots
  • booted without the NVMe
  • reseated the display cable
  • mainboard reset (10× chassis switch)
Same code every time.
RAM: Kingston FURY Impact KF556S40IBK2-32 (2×16 GB DDR5-5600 CL40, non-XMP). The DRAM chips are Kingston-branded: D2048FNAACG5B / N452271W3E, date 2521, PCB 99U5790-011.A00GF (photo attached).
On r/framework and in older threads here, people report that this same part number works on AI 300 boards when it has SK Hynix or Samsung chips, but gives exactly this 0xA3 code with Kingston-branded chips. So the part number alone doesn’t tell you whether it will work.
The Framework DDR5-5600 modules are sold out, so I ordered a Crucial CT2K16G56C46S5 kit and will report back.
Questions for Framework:
  1. What do post codes 0xA3 and 0x47 mean on the AI 300 board? Could you publish the LED/post code table for the AMD boards? The KB only covers 11th Gen Intel.
  2. Is the Crucial CT2K16G56C46S5 kit compatible with the Laptop 13 Pro AMD?
  3. Could the Kingston-chip variant be investigated (BIOS memory training) or marked on the compatibility list?
Tip for others: before buying Kingston FURY for an AI 300 board, check (or ask the seller) which DRAM chips are on it.
Correction to my first post, plus what I found in the meantime.
I had the code wrong. I wrote 0xA3 followed by 0x47, but I read the blinks the wrong way around. The EC shows the code lowest bit first, so my pattern (BGBGGGBB GBGGGBBB) is actually 0xE2C5. To be honest, I didn’t figure this out alone: I went through it with Claude (AI), which dug through the EC source and the BIOS with me. Without that I wouldn’t have gotten this far.
Reading the LED code
From diagnostics_laptop.c in Framework’s EmbeddedController repo: after about 90 seconds without a successful boot, the LED blinks:
white               start
12x red/green       hardware checks (red = problem)
                    1 battery, 2 PGOOD 3V/5V, 3 VCCIN AUX VR, 4 SLP_S4,
                    5 PGOOD VR, 6 touchpad, 7 audio board, 8 thermal sensor,
                    9 fan, 10 no S0, 11 no DDR, 12 no eDP
amber               separator
16x blue/green      last port 80 code, blue = 1, green = 0
                    LOWEST BIT FIRST: blinks 1-8 = low byte, 9-16 = high byte
So write the 16 blinks down and read them backwards. Or:
s = "BGBGGGBB GBGGGBBB".replace(" ", "")   # the blinks in the order you saw them
print(hex(sum((c == "B") << i for i, c in enumerate(s))))   # 0xe2c5
In this older topic someone with the same Kingston kit on an AI 300 had exactly the same first eight blinks (BGBGGGBB) and read it as “0xC5”. Same error.
What 0xE2C5 means
The KB only has the Intel codes. AMD’s ABL code list does show up in Cisco’s service guide for their UCS C885A M8 (EPYC). It’s a server table, so not officially confirmed for the AI 300, but it uses the same code range. There 0xE2C5 = “ABL Error for PMU Training error”, meaning the DRAM training failed. The full list with blink patterns is at the bottom of this post.
What the BIOS does
I unpacked the ABL from BIOS 4.02 (ABL v53.18.D0.A0). psptool says it’s broken/encrypted, but it is just 19 zlib streams with readable debug strings. Roughly:
  • It reads the SPD, trains at the SPD speed (5600) at a fixed 1.1 V.
  • If training fails: retry (if enabled), then ABL stop on PMU training failure, and it stops. I didn’t see any fallback to a lower speed like 4800.
  • There are small vendor-specific tweaks for Samsung, SK Hynix and Micron dies only. Everything else gets the generic settings. I don’t think that’s the whole story, since the tweaks are minor. More likely the Kingston-made chips just don’t have enough margin at 5600 on this board.
So it’s not the mainboard. It’s this Kingston kit with Kingston’s own DRAM chips. Same part number with Hynix/Samsung chips reportedly works fine. I’ve got a Crucial CT2K16G56C46S5 (Micron) on the way and will report back.
For Framework, if you read this:
  1. Can you confirm 0xE2C5 on the AI 300, and put the AMD codes plus the “lowest bit first” reading in the KB? I clearly wasn’t the only one reading it backwards.
  2. Would a fallback to a lower speed after failed training be possible? Then unlisted RAM at least boots.
  3. Maybe add a note to the RAM guidance about the KF556S40IBK2-32 / KF556S40IB-16 with Kingston chips.
All codes
About 280 ABL codes that can come up on a laptop, with the blink pattern next to each one. Server-only stuff is left out. Codes without “error” are progress steps: if it hangs, you see the last step it reached.
AMD ABL codes with blink patterns (click to expand)
Code Blinks 1-8 | 9-16 Meaning (B=blue=1, G=green=0, LSB first)
0xB1C0 GGGGGGBB BGGGBBGB 3 GMI/xGMI Initialization Stage 1 Warning
0xB2C0 GGGGGGBB GBGGBBGB 3 GMI/xGMI Initialization Stage 2 Warning
0xB3C0 GGGGGGBB BBGGBBGB 3 GMI/xGMI Initialization Stage 3 Warning
0xB4C0 GGGGGGBB GGBGBBGB 3 GMI/xGMI Initialization Stage 4 Warning
0xB5C0 GGGGGGBB BGBGBBGB 3 GMI/xGMI Initialization Stage 5 Warning
0xB6C0 GGGGGGBB GBBGBBGB 3 GMI/xGMI Initialization Stage 6 Warning
0xE02A GBGBGBGG GGGGGBBB Mem - ProcMemTransmitDqsTraining
0xE02B BBGBGBGG GGGGGBBB Mem - Start write sweep
0xE02C GGBBGBGG GGGGGBBB Mem - Set Transmit DQ delay
0xE02D BGBBGBGG GGGGGBBB Mem - Write test pattern
0xE02E GBBBGBGG GGGGGBBB Mem - Read Test pattern
0xE02F BBBBGBGG GGGGGBBB Mem - Compare Test pattern
0xE030 GGGGBBGG GGGGGBBB Mem - Update results
0xE031 BGGGBBGG GGGGGBBB Mem - Start Find passing window
0xE032 GBGGBBGG GGGGGBBB Mem - ProcMemMaxRdLatencyTraining
0xE033 BBGGBBGG GGGGGBBB Mem - Start sweep
0xE034 GGBGBBGG GGGGGBBB Mem - Set delay
0xE035 BGBGBBGG GGGGGBBB Mem - Write test pattern
0xE036 GBBGBBGG GGGGGBBB Mem - Read Test pattern
0xE037 BBBGBBGG GGGGGBBB Mem - Compare Test pattern
0xE038 GGGBBBGG GGGGGBBB Mem - Online Spare init
0xE039 BGGBBBGG GGGGGBBB Mem - Chip select Interleave Init
0xE03A GBGBBBGG GGGGGBBB Mem - Node Interleave Init
0xE03B BBGBBBGG GGGGGBBB Mem - Channel Interleave Init
0xE03C GGBBBBGG GGGGGBBB Mem - ECC initialization
0xE03D BGBBBBGG GGGGGBBB Mem - Platform Specific Init
0xE03E GBBBBBGG GGGGGBBB Mem - Before callout for “AgesaReadSpd”
0xE03F BBBBBBGG GGGGGBBB Mem - After callout for “AgesaReadSpd”
0xE040 GGGGGGBG GGGGGBBB Mem - Before optional callout “AgesaHookBeforeDramInit”
0xE041 BGGGGGBG GGGGGBBB Mem - After optional callout “AgesaHookBeforeDramInit”
0xE042 GBGGGGBG GGGGGBBB Mem - Before optional callout “AgesaHookBeforeDQSTraining”
0xE043 BBGGGGBG GGGGGBBB Mem - After optional callout “AgesaHookBeforeDQSTraining”
0xE044 GGBGGGBG GGGGGBBB Mem - Before optional callout “AgesaHookBeforeDramInit”
0xE045 BGBGGGBG GGGGGBBB Mem - After optional callout “AgesaHookBeforeDramInit”
0xE046 GBBGGGBG GGGGGBBB Mem - After MemDataInit
0xE047 BBBGGGBG GGGGGBBB Mem - Before InitializeMCT
0xE048 GGGBGGBG GGGGGBBB Mem - Before LV DDR3
0xE049 BGGBGGBG GGGGGBBB Mem - Before InitMCT
0xE04A GBGBGGBG GGGGGBBB Mem - Before OtherTiming
0xE04B BBGBGGBG GGGGGBBB Mem - Before UMAMemTyping
0xE04C GGBBGGBG GGGGGBBB Mem - Before SetDqsEccTmgs
0xE04D BGBBGGBG GGGGGBBB Mem - Before MemClr
0xE04E GBBBGGBG GGGGGBBB Mem - Before On DIMM Thermal
0xE04F BBBBGGBG GGGGGBBB Mem - Before DMI
0xE050 GGGGBGBG GGGGGBBB MEM - End of phase 3 memory code
0xE051 BGGGBGBG GGGGGBBB Entry point CPU init after training
0xE052 GBGGBGBG GGGGGBBB Exit point CPU init after training
0xE053 BBGGBGBG GGGGGBBB Entry point CPU APOB data init
0xE054 GGBGBGBG GGGGGBBB Exit point CPU APOB data init
0xE055 BGBGBGBG GGGGGBBB Entry point CPU Optimized boot init
0xE056 GBBGBGBG GGGGGBBB Exit point CPU Optimized boot init
0xE057 BBBGBGBG GGGGGBBB Entry point CPU APOB EDC info init
0xE058 GGGBBGBG GGGGGBBB Exit point CPU APOB EDC info init
0xE059 BGGBBGBG GGGGGBBB Entry point CPU APOB CCD map data init
0xE05A GBGBBGBG GGGGGBBB Exit point CPU APOB CCD map data init
0xE080 GGGGGGGB GGGGGBBB ProcMemSendMRS2
0xE081 BGGGGGGB GGGGGBBB Sedding MRS3
0xE082 GBGGGGGB GGGGGBBB Sending MRS1
0xE083 BBGGGGGB GGGGGBBB Sending MRS0
0xE084 GGBGGGGB GGGGGBBB Continuous Pattern Read
0xE085 BGBGGGGB GGGGGBBB Continuous Pattern Write
0xE086 GBBGGGGB GGGGGBBB Mem: 2d RdDqs Training begin
0xE087 BBBGGGGB GGGGGBBB Mem: Before optional callout to platform BIOS to change Ex
0xE088 GGGBGGGB GGGGGBBB Mem: After optional callout to platform BIOS to change Ext
0xE089 BGGBGGGB GGGGGBBB Configure DCT For General use begin
0xE08A GBGBGGGB GGGGGBBB Configure DCT For training begin
0xE08B BBGBGGGB GGGGGBBB Configure DCT For Non-Explicit
0xE08C GGBBGGGB GGGGGBBB Configure to Sync channels
0xE08D BGBBGGGB GGGGGBBB Allocate C6 Storage
0xE08E GBBBGGGB GGGGGBBB Before LV DDR4
0xE08F BBBBGGGB GGGGGBBB Before LV DDR3
0xE090 GGGGBGGB GGGGGBBB TP0x90
0xE091 BGGGBGGB GGGGGBBB GNB earlier interface
0xE092 GBGGBGGB GGGGGBBB GNB Early VGA entry
0xE093 BBGGBGGB GGGGGBBB GNB Early VGA exit
0xE094 GGBGBGGB GGGGGBBB GNB Initialization entry
0xE095 BGBGBGGB GGGGGBBB GNB Initialization exit
0xE096 GBBGBGGB GGGGGBBB GNB internal debug code
0xE097 BBBGBGGB GGGGGBBB GNB internal debug code
0xE098 GGGBBGGB GGGGGBBB GNB internal debug code
0xE099 BGGBBGGB GGGGGBBB GNB internal debug code
0xE09A GBGBBGGB GGGGGBBB GNB internal debug code
0xE09B BBGBBGGB GGGGGBBB GNB internal debug code
0xE09C GGBBBGGB GGGGGBBB GNB internal debug code
0xE09D BGBBBGGB GGGGGBBB GNB internal debug code
0xE09E GBBBBGGB GGGGGBBB GNB internal debug code
0xE09F BBBBBGGB GGGGGBBB GNB internal debug code
0xE0A0 GGGGGBGB GGGGGBBB TP0xA0
0xE0A1 BGGGGBGB GGGGGBBB GNB internal debug code
0xE0A2 GBGGGBGB GGGGGBBB GNB internal debug code
0xE0A3 BBGGGBGB GGGGGBBB GNB internal debug code
0xE0A4 GGBGGBGB GGGGGBBB GNB internal debug code
0xE0A5 BGBGGBGB GGGGGBBB GNB internal debug code
0xE0A6 GBBGGBGB GGGGGBBB GNB internal debug code
0xE0A7 BBBGGBGB GGGGGBBB GNB internal debug code
0xE0A8 GGGBGBGB GGGGGBBB GNB internal debug code
0xE0A9 BGGBGBGB GGGGGBBB GNB internal debug code
0xE0AA GBGBGBGB GGGGGBBB GNB internal debug code
0xE0AB BBGBGBGB GGGGGBBB GNB internal debug code
0xE0AC GGBBGBGB GGGGGBBB GNB internal debug code
0xE0AD BGBBGBGB GGGGGBBB GNB internal debug code
0xE0AE GBBBGBGB GGGGGBBB GNB internal debug code
0xE0AF BBBBGBGB GGGGGBBB GNB internal debug code
0xE0B0 GGGGBBGB GGGGGBBB Abl1Begin
0xE0B1 BGGGBBGB GGGGGBBB 1 Initialization
0xE0B2 GBGGBBGB GGGGGBBB 1 DF Early
0xE0B3 BBGGBBGB GGGGGBBB 1 DF Pre Training
0xE0B4 GGBGBBGB GGGGGBBB 1 Debug Synchronization
0xE0B5 BGBGBBGB GGGGGBBB 1 Detected
0xE0B6 GBBGBBGB GGGGGBBB 1 Global memory detected
0xE0B7 BBBGBBGB GGGGGBBB 1 End
0xE0B8 GGGBBBGB GGGGGBBB 2 Begin
0xE0B9 BGGBBBGB GGGGGBBB 2 Initialization
0xE0BA GBGBBBGB GGGGGBBB 2 After Training
0xE0BB BBGBBBGB GGGGGBBB 2 Debug Synchronization
0xE0BC GGBBBBGB GGGGGBBB 2 detected
0xE0BD BGBBBBGB GGGGGBBB 2 Global memory detected
0xE0BE GBBBBBGB GGGGGBBB 2 End
0xE0BF BBBBBBGB GGGGGBBB 3 Begin
0xE0C0 GGGGGGBB GGGGGBBB 3 Initialization
0xE0C1 BGGGGGBB GGGGGBBB Abl3ProgramUmcKeys
0xE0C2 GBGGGGBB GGGGGBBB 3 DF Final Initialization
0xE0C3 BBGGGGBB GGGGGBBB 3 Execute Synchronization Function
0xE0C4 GGBGGGBB GGGGGBBB 3 Debug Synchronization Function
0xE0C5 BGBGGGBB GGGGGBBB 3 Detected
0xE0C6 GBBGGGBB GGGGGBBB 3 Global memory detected
0xE0C7 BBBGGGBB GGGGGBBB 4 Initialization - cold boot
0xE0C8 GGGBGGBB GGGGGBBB 4 Memory test - cold boot
0xE0C9 BGGBGGBB GGGGGBBB 4 APOB Initialization - cold boot
0xE0CA GBGBGGBB GGGGGBBB 4 Finalize memory settings - cold boot
0xE0CB BBGBGGBB GGGGGBBB 4 CPU Initialize Optimized Boot - cold boot
0xE0CC GGBBGGBB GGGGGBBB 4 Gmi Pcie Training - cold boot
0xE0CD BGBBGGBB GGGGGBBB 4 Cold boot End
0xE0CE GBBBGGBB GGGGGBBB 4 Initialization - Resume boot
0xE0CF BBBBGGBB GGGGGBBB 4 Resume End
0xE0D0 GGGGBGBB GGGGGBBB 4 End Cold/Resume boot
0xE0D1 BGGGBGBB GGGGGBBB 2 memory initialization
0xE0D2 GBGGBGBB GGGGGBBB 3 memory initialization
0xE0D3 BBGGBGBB GGGGGBBB 3 End
0xE0D4 GGBGBGBB GGGGGBBB 1 Enter Memory Flow
0xE0D5 BGBGBGBB GGGGGBBB Memory flow memory clock synchronization
0xE0E0 GGGGGBBB GGGGGBBB Before IDS calls out to get IDS data
0xE0E1 BGGGGBBB GGGGGBBB After IDS calls out to get IDS data
0xE0F9 BGGBBBBB GGGGGBBB Failed PMU training.
0xE0FA GBGBBBBB GGGGGBBB End of phase 1 memory code
0xE0FB BBGBBBBB GGGGGBBB End of phase 2 memory code
0xE0FC GGBBBBBB GGGGGBBB Abl0Begin
0xE0FD BGBBBBBB GGGGGBBB 0 End
0xE0FE GBBBBBBB GGGGGBBB Abl0 Begin with Fatal Mode
0xE0FF BBBBBBBB GGGGGBBB 0 End with Fatal Mode
0xE100 GGGGGGGG BGGGGBBB 7 End
0xE101 BGGGGGGG BGGGGBBB 7 Resume boot
0xE102 GBGGGGGG BGGGGBBB 6 End
0xE103 BBGGGGGG BGGGGBBB 6 Initialization
0xE104 GGBGGGGG BGGGGBBB End of phase 1b memory code
0xE105 BGBGGGGG BGGGGBBB 1b memory initialization
0xE106 GBBGGGGG BGGGGBBB 6 Global memory detected
0xE107 BBBGGGGG BGGGGBBB 1b Debug Synchroniza0ion Function
0xE108 GGGBGGGG BGGGGBBB 4b Debug Synchronization Function
0xE109 BGGBGGGG BGGGGBBB AblbBegin
0xE10A GBGBGGGG BGGGGBBB Ab4bBegin
0xE10B BBGBGGGG BGGGGBBB BSP encountered HMAC fail on APOB Header
0xE10C GGBBGGGG BGGGGBBB 18 End
0xE10D BGBBGGGG BGGGGBBB 18 Resume boot
0xE10E GBBBGGGG BGGGGBBB 15 End
0xE10F BBBBGGGG BGGGGBBB 15 Initialization
0xE110 GGGGBGGG BGGGGBBB Before UMC based device initialization
0xE111 BGGGBGGG BGGGGBBB After UMC based device initialization
0xE1C0 GGGGGGBB BGGGGBBB 3 GMI/xGMI Initialization Stage 1
0xE2A0 GGGGGBGB GBGGGBBB General ASSERT
0xE2A1 BGGGGBGB GBGGGBBB Unknown
0xE2A3 BBGGGBGB GBGGGBBB Log Inig
0xE2A4 GGBGGBGB GBGGGBBB On DIMM thermal Heap allocation
0xE2A5 BGBGGBGB GBGGGBBB memory test
0xE2A6 GBBGGBGB GBGGGBBB while executing memory test
0xE2A7 BBBGGBGB GBGGGBBB DDR Post Package Repair Mem Auto Heap Alloc
0xE2A8 GGGBGBGB GBGGGBBB DDR Post Package repair Apob Heap Alloc
0xE2A9 BGGBGBGB GBGGGBBB DDR Post Package Repair No PPR
0xE2AA GBGBGBGB GBGGGBBB Ecc Mem Auto Aloc
0xE2AB BBGBGBGB GBGGGBBB Soc Scan Heap Aloc
0xE2AC GGBBGBGB GBGGGBBB Soc Scan No Die
0xE2AD BGBBGBGB GBGGGBBB Nb Tech Heap Aloc
0xE2AE GBBBGBGB GBGGGBBB No Nb Constructor
0xE2B0 GGGGBBGB GBGGGBBB No Tech Constructor
0xE2B1 BGGGBBGB GBGGGBBB ABL1b Auto Alocation
0xE2B2 GBGGBBGB GBGGGBBB ABL1b No NB Constructor
0xE2B3 BBGGBBGB GBGGGBBB ABL2 No Nb Constructor
0xE2B4 GGBGBBGB GBGGGBBB ABL3 Auto Allocation
0xE2B5 BGBGBBGB GBGGGBBB ABL3 No Nb Constructor
0xE2B6 GBBGBBGB GBGGGBBB ABL1b General
0xE2B7 BBBGBBGB GBGGGBBB ABL2 General
0xE2B8 GGGBBBGB GBGGGBBB ABL3 General
0xE2B9 BGGBBBGB GBGGGBBB Get Target Speed
0xE2BA GBGBBBGB GBGGGBBB Flow P1 Family Support
0xE2BB BBGBBBGB GBGGGBBB No Valid Ddr4 Dimms
0xE2BC GGBBBBGB GBGGGBBB No Dimm Present
0xE2BD BGBBBBGB GBGGGBBB Flow P2 Family Support
0xE2BE GBBBBBGB GBGGGBBB Heap Deallocation for PMU Sram Msg Block
0xE2BF BBBBBBGB GBGGGBBB DDR Recovery
0xE2C0 GGGGGGBB GBGGGBBB 3 GMI/xGMI Initialization Stage 2
0xE2C1 BGGGGGBB GBGGGBBB On Die Thermal
0xE2C2 GBGGGGBB GBGGGBBB Heap Allocation For Dct Struct Amd Ch Def structure
0xE2C3 BBGGGGBB GBGGGBBB Heap Allocation for PMU SRAM Msg block
0xE2C4 GGBGGGBB GBGGGBBB Heap Phy PLL lock Flure
0xE2C5 BGBGGGBB GBGGGBBB Pmu Training
0xE2C6 GBBGGGBB GBGGGBBB Failure to Load or Verify PMU FW
0xE2C7 BBBGGGBB GBGGGBBB Allocate for PMU SRAM Msg Block No Init
0xE2C8 GGGBGGBB GBGGGBBB Failure BIOS PMU FW Mismatch AGESA PMU FW version
0xE2C9 BGGBGGBB GBGGGBBB Agesa memory test
0xE2CA GBGBGGBB GBGGGBBB Deallocate for PMU SRAM Msg Block
0xE2CB BBGBGGBB GBGGGBBB Module Type Mismatch RDIMM
0xE2CC GGBBGGBB GBGGGBBB Module type Mismatch LRDIMM
0xE2CD BGBBGGBB GBGGGBBB MEm Auto NVDIM
0xE2CE GBBBGGBB GBGGGBBB Unknown Response
0xE2CF BBBBGGBB GBGGGBBB Over Clock RRW Test Results
0xE2D0 GGGGBGBB GBGGGBBB Over Clock PMU Training
0xE2D1 BGGGBGBB GBGGGBBB ABL1 General
0xE2D2 GBGGBGBB GBGGGBBB ABL2 General
0xE2D3 BBGGBGBB GBGGGBBB ABL3 General
0xE2D4 GGBGBGBB GBGGGBBB ABL4 General
0xE2D5 BGBGBGBB GBGGGBBB over clock Mem Init
0xE2D6 GBBGBGBB GBGGGBBB over clock Mem Other
0xE2D7 BBBGBGBB GBGGGBBB ABL6 General
0xE2D8 GGGBBGBB GBGGGBBB Event Log
0xE2D9 BGGBBGBB GBGGGBBB FATAL ABL1 Log
0xE2DA GBGBBGBB GBGGGBBB FATAL ABL2 Log
0xE2DB BBGBBGBB GBGGGBBB FATAL ABL3 Log
0xE2DC GGBBBGBB GBGGGBBB FATAL ABL4 Log
0xE2DD BGBBBGBB GBGGGBBB Slave Sync function execution
0xE2DE GBBBBGBB GBGGGBBB Slave Sync communication with data set to master
0xE2DF BBBBBGBB GBGGGBBB Slave broadcast communication from master to slave
0xE2E0 GGGGGBBB GBGGGBBB FATAL ABL6 Log
0xE2E1 BGGGGBBB GBGGGBBB Slave Offline
0xE2E2 GBGGGBBB GBGGGBBB Slave Informs Master Info
0xE2E3 BBGGGBBB GBGGGBBB Heap Locate for PMU SRAM Msg Block
0xE2E4 GGBGGBBB GBGGGBBB ABL2 Auto
0xE2E5 BGBGGBBB GBGGGBBB Flow P3 Family support
0xE2E7 BBBGGBBB GBGGGBBB Mix RDIMM and LRDIMM in a channel
0xE2E8 GGGBGBBB GBGGGBBB Memory Present on Disconnected Channel
0xE2EB BBGBGBBB GBGGGBBB MBIST Heap Allocation
0xE2EC GGBBGBBB GBGGGBBB MBIST Results
0xE2ED BGBBGBBB GBGGGBBB NO Dimm Smcus Info
0xE2EE GBBBGBBB GBGGGBBB Por Max Freq
0xE2EF BBBBGBBB GBGGGBBB Unsupported DIMM Config
0xE2F0 GGGGBBBB GBGGGBBB No Ps
0xE2F1 BGGGBBBB GBGGGBBB Cad Bus Timing Not Found
0xE2F2 GBGGBBBB GBGGGBBB Data Bus Timing Not Found
0xE2F3 BBGGBBBB GBGGGBBB LrDIMM IBT Not Found
0xE2F4 GGBGBBBB GBGGGBBB Unsupported Dimm Config Max Freq
0xE2F5 BGBGBBBB GBGGGBBB Mr0 Not Found
0xE2F6 GBBGBBBB GBGGGBBB Obt Pattern Not found
0xE2F7 BBBGBBBB GBGGGBBB Rc10 Op Speed Not FOund
0xE2F8 GGGBBBBB GBGGGBBB Rc2 Ibt Not Found
0xE2F9 BGGBBBBB GBGGGBBB Rtt Not Found
0xE2FA GBGBBBBB GBGGGBBB Checksum ReStrt Results
0xE2FB BBGBBBBB GBGGGBBB No Chipselect Results
0xE2FC GGBBBBBB GBGGGBBB No Common Cas Latency Results
0xE2FD BGBBBBBB GBGGGBBB Cas Latency exceeds Taa Max
0xE2FE GBBBBBBB GBGGGBBB Nvdimm Arm Mismatch Power Policy
0xE2FF BBBBBBBB GBGGGBBB Nvdimm Arm Mismatch Power Source
0xE300 GGGGGGGG BBGGGBBB ABL 1 Mem Init
0xE301 BGGGGGGG BBGGGBBB ABL 2 Mem Init
0xE302 GBGGGGGG BBGGGBBB ABL 4 Mem Init
0xE303 BBGGGGGG BBGGGBBB ABL 6 Mem Init
0xE304 GGBGGGGG BBGGGBBB ABL 1 repor
0xE305 BGBGGGGG BBGGGBBB ABL 2 repor
0xE306 GBBGGGGG BBGGGBBB ABL 3 repor
0xE307 BBBGGGGG BBGGGBBB ABL 4 repor
0xE308 GGGBGGGG BBGGGBBB ABL 6 repor
0xE30A GBGBGGGG BBGGGBBB message slave sync function execution
0xE30B BBGBGGGG BBGGGBBB slave offline
0xE30C GGBBGGGG BBGGGBBB Sync Master
0xE30D BGBBGGGG BBGGGBBB Slave Informs Master Info Message
0xE30E GBBBGGGG BBGGGBBB Mix Hynix LRDIMM with other vendor LRDIMM in a channel
0xE30F BBBBGGGG BBGGGBBB General Assert
0xE310 GGGGBGGG BBGGGBBB ErrorNo Dimms On Any Channel in system
0xE311 BGGGBGGG BBGGGBBB Shared Heap Aloc
0xE312 GBGGBGGG BBGGGBBB Main Heap Aloc
0xE313 BBGGBGGG BBGGGBBB Shared Heap loc
0xE314 GGBGBGGG BBGGGBBB Main Heap loc
0xE316 GBBGBGGG BBGGGBBB No memory available in system
0xE320 GGGGGBGG BBGGGBBB Mixed Ecc and Non-Ecc DIMM in a channel
0xE321 BGGGGBGG BBGGGBBB Mixed 3DS and Non-3DS DIMM in a channel
0xE322 GBGGGBGG BBGGGBBB Mixed x4 and x8 DIMM in a channel
0xE323 BBGGGBGG BBGGGBBB Memory MBIST Rrw default test
0xE324 GGBGGBGG BBGGGBBB Memory MBIST Interface test
0xE325 BGBGGBGG BBGGGBBB Memory MBIST DataEye
0xE326 GBBGGBGG BBGGGBBB Memory Post Package Repair
0xE327 BBBGGBGG BBGGGBBB S0i3 DF restore buffer
0xE328 GGGBGBGG BBGGGBBB CPU OPN Mismatch in case of Multi Socket population
0xE329 BGGBGBGG BBGGGBBB Recoverable APCB Checksum
0xE32A GBGBGBGG BBGGGBBB Fatal APCB Checksum
0xE32B BBGBGBGG BBGGGBBB BIST Failure
0xE32C GGBBGBGG BBGGGBBB DDR Type Mismatch DDR5
0xE32D BGBBGBGG BBGGGBBB Mix DIMM with different ECC bit size in a channel
0xE32E GBBBGBGG BBGGGBBB No ability to recover I2C bus without power cycling the pl
0xE32F BBBBGBGG BBGGGBBB I2C reset failure
0xE330 GGGGBBGG BBGGGBBB DDR Module Type Mismatch
0xE331 BGGGBBGG BBGGGBBB PMIC
0xE332 GBGGBBGG BBGGGBBB Incompatible OPN
0xE333 BBGGBBGG BBGGGBBB No ability to recover I3C bus without power cycling the pl
0xE334 GGBGBBGG BBGGGBBB I3C reset failure
0xE335 BGBGBBGG BBGGGBBB Absence of either or both AC-Power GPIO or WLAN GPIO Apcb
0xE336 GBBGBBGG BBGGGBBB Memory Heal BIST Start
0xE337 BBBGBBGG BBGGGBBB Memory Heal BIST End
0xE338 GGGBBBGG BBGGGBBB Memory Heal BIST Write
0xE339 BGGBBBGG BBGGGBBB Memory Heal BIST Read
0xE33A GBGBBBGG BBGGGBBB Memory Heal BIST Repair
0xE33B BBGBBBGG BBGGGBBB Timeout at PMFW SwitchToMemoryTrainingState
0xE33C GGBBBBGG BBGGGBBB DIMM with RCD Montage version B1 detected
0xE33D BGBBBBGG BBGGGBBB DDR PMU training complete
0xE33E GBBBBBGG BBGGGBBB Timeout at PMFW SwitchToMemoryTrainingState
0xE33F BBBBBBGG BBGGGBBB DIMM with TI PMIC revision 1.1 (XTPS) detected
0xE343 BBGGGGBG BBGGGBBB DDR DIMM SPD verify CRC failure
0xE344 GGBGGGBG BBGGGBBB DDR DIMM SPD Invalid Field Value
0xE345 BGBGGGBG BBGGGBBB Timeout to detect CPU OPN Mismatch in case of Multi Socket
0xE346 GBBGGGBG BBGGGBBB 3DS DIMM in a SP6 system
0xE350 GGGGBGBG BBGGGBBB DDR Runtime Post Package Repair Begin
0xE351 BGGGBGBG BBGGGBBB DDR Runtime Post Package Repair End
0xE3C0 GGGGGGBB BBGGGBBB 3 GMI/xGMI Initialization Stage 3
0xE4C0 GGGGGGBB GGBGGBBB 3 GMI/xGMI Initialization Stage 4
0xE5C0 GGGGGGBB BGBGGBBB 3 GMI/xGMI Initialization Stage 5
0xE60B BBGBGGGG GBBGGBBB Functions execute Before
0xE60C GGBBGGGG GBBGGBBB Functions execute
0xE6C0 GGGGGGBB GBBGGBBB 3 GMI/xGMI Initialization Stage 6
0xE7C0 GGGGGGBB BBBGGBBB 3 GMI/xGMI Initialization Stage 7
0xE8C0 GGGGGGBB GGGBGBBB 3 GMI/xGMI Initialization Stage 8
0xE9C0 GGGGGGBB BGGBGBBB 3 GMI/xGMI Initialization Stage 9
0xEA00 GGGGGGGG GBGBGBBB Begin
0xEA01 BGGGGGGG GBGBGBBB End
0xEA10 GGGGBGGG GBGBGBBB Debug Synchronization
0xEAC0 GGGGGGBB GBGBGBBB 3 GMI/xGMI Initialization Stage 10
0xEBC0 GGGGGGBB BBGBGBBB RRW Test
0xEFFF BBBBBBBB BBBBGBBB EndAgesas BIOS POST Codes
0xF1C0 GGGGGGBB BGGGBBBB 3 GMI/xGMI Initialization Stage 2
0xF2C0 GGGGGGBB GBGGBBBB 3 GMI/xGMI Initialization Stage 2
0xF3C0 GGGGGGBB BBGGBBBB 3 GMI/xGMI Initialization Stage 3
0xF4C0 GGGGGGBB GGBGBBBB 3 GMI/xGMI Initialization Stage 4
0xF5C0 GGGGGGBB BGBGBBBB 3 GMI/xGMI Initialization Stage 5
0xF6C0 GGGGGGBB GBBGBBBB 3 GMI/xGMI Initialization Stage 6
0xF9C0 GGGGGGBB BGGBBBBB 3 GMI/xGMI Initialization Stage 9
0xFAC0 GGGGGGBB GBGBBBBB 3 GMI/xGMI Initialization Stage 10
The TL;Dr is: Stop buying Kingston Fury SODIMMS for Framework boards. It is well documented that this vendor/line of modules do not play well.
Sure, sometimes they do when they are populated with certain chips but why take the chance when there are others out there that do not have this issue.
Is there a fire sale of Kingston laptop memory somewhere?
One of the common links is “Well this one has the lowest CAS timing and I want the fastest I can get…” It’s 5600Mhz memory. It is not breaking world records.
No need for the lecture. I’m clearly not the first one to run into this, and I won’t be the last. A simple “known issue, bad luck” would have been enough.
Anyway, for anyone who finds this thread: the Crucial CT2K16G56C46S5 (Micron chips) booted on the first try and runs at 5600 on the HX 370..
With crucial exiting the market kingston are one of the bigger manufacturers of sodimms selling to consumers left so even without them having “better numbers” it would not be that unexpected for people to find/have kingston sticks.
