Laptop 16 - Primary and Secondary NVMe - With Graphics module
I’m a bit confused about the Primary and Secondary storage with a Graphics Module installed on the system. I was hoping someone could clear it up for me.
I am aware I can use the Bay module to gain more storage, but I’m not looking to use that module.
I’m looking to get a laptop 16 with the graphics module, but I’m told only one NVMe will fit into one of the slots (2230 or 2280). From the images presented from the creation page, I can’t tell if you can insert two (2230 and 2280). From the view it looks like you could install both?
I do not plan to buy the computer until I can get this question cleared up.
Thanks
Welcome to the community @Brandon_Stensny!
The Framework Laptop 16 can natively take 1 2280 and 1 2230 NVMe drive at the same time. The graphics card option will use the expansion module at the back of the laptop.
In my machine I have a 2TB 2280 drive and a 1TB 2230 drive. Hope this helps you.
It does! Thanks.
