could be related to divinitus’ topic:
System
- Framework Laptop 16, AMD Ryzen AI 9 HX 370, RTX 5070 graphics module
- BIOS 04.01, all firmware up to date via
fwupdmgr - Debian 13 (trixie), kernel 7.1.8+deb13-amd64
- GNOME 48.7 (Wayland), dGPU driven by nouveau
- External monitor: iiyama PL3288UH (3840x2160 @ 60 Hz) via the HDMI Expansion Card, used as the only active display
Symptom
With the HDMI Expansion Card in the middle-right slot, the external monitor goes black for a few seconds (sometimes I have to replug the card). GNOME falls back to the internal panel, then switches back once the monitor returns. In daily use it is triggered by pressing Super and typing an app name.
What the logs show
The HDMI card drops off the USB bus at the moment the dGPU resumes from runtime suspend:
15:09:07.918427 kernel: usb 3-2.2: USB disconnect, device number 14
15:09:08.327654 kernel: nouveau 0000:c1:00.0: Enabling HDA controller
15:09:10.951645 kernel: usb 3-2.2: new full-speed USB device number 16 using xhci_hcd
15:09:11.084052 kernel: usb 3-2.2: Product: HDMI Expansion Card
15:09:11.235772 kernel: rc rc0: DP-1 as /devices/pci0000:00/0000:00:08.1/0000:c2:00.0/rc/rc0
The GNOME shortcut only matters because opening the overview starts apps that wake the dGPU. I can reproduce it without GNOME:
# with power/control=auto and runtime_status=suspended
echo on | sudo tee /sys/bus/pci/devices/0000:c1:00.0/power/control
# -> external monitor goes black, HDMI card disconnects/re-enumerates
Workarounds that work
- Keeping the dGPU awake (
power/control=on): the bug no longer occurs. - Moving the HDMI card to the top-left slot. There, the dGPU woke three times without any disconnect:
15:28:04.731685 kernel: rc rc0: DP-4 as /devices/pci0000:00/0000:00:08.1/0000:c2:00.0/rc/rc0
15:28:04.775681 kernel: hid-generic ...: [Framework HDMI Expansion Card] on usb-0000:c4:00.4-1/input1
15:28:56.251651 kernel: nouveau 0000:c1:00.0: Enabling HDA controller
15:30:31.871652 kernel: nouveau 0000:c1:00.0: Enabling HDA controller
15:33:16.203663 kernel: nouveau 0000:c1:00.0: Enabling HDA controller
Observations
- In the affected slot the card shows up as
usb 3-2.2(behind a hub onc4:00.0). In the working slot it isusb 7-1onc4:00.4. - The whole card disconnects, not just the video signal. That looks like the port losing power or resetting when the dGPU powers up, rather than a display driver issue.
- The middle-right slot is listed as supporting DisplayPort/HDMI up to 4K, so I expected it to work.
Questions
- Is this a known issue with the middle-right slot when a dGPU module is installed?
- Could a BIOS/EC update fix it, or is it a hardware limitation of that slot?
- Can other Laptop 16 + RTX 5070 owners reproduce it with the
echo ontest above?
Full logs available on request.
