Hi,
I recently updated the firmware of my Framework laptop to BIOS 04.05. Since then it won’t charge when I unplug and then replug the USB-C charger cable. I have to reboot the device to temporarily fix this.
- OS: Linux, openSUSE Tumbleweed, kernel 7.1.8-1-default
- Framework Laptop 16 AMD 7040 with dGPU
- Charger: Standard Framework charger that came with the laptop
I’ve also tried it with Windows 11 (dual boot) and there the issue is the same.
I definitely did not have the issue before the BIOS update. How can I fix this or what additional info should I provide?
Kind regards
