Ubunutu
Which release version?
Which kernel are you using?
6.17.0-8-generic
04.02
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
16inch AMD RYzen 7040 series
I have two HP V28 4K monitors. I have used this setup for a year without issue on a Windows HP laptop. Recently, I switched to a Framework laptop, and it will intermittently fail to recognize one of the monitors connected through a USB docker. The docker works fine, as the other peripherals I have hooked through it (keyboard and mouse) work fine.
But every few days, the laptop will fail to recognize the monitor linked through the docker. I then spend a lot of time messing around with swapping ports around the Framework, which usually solves this issue.
Does anyone know why this is? Why do I have to reconfigure my ports every few days?
