# Laptop will not power on
**URL:** <https://community.frame.work/t/laptop-will-not-power-on/29700>\
**Category:** Framework Laptop 13\
**Created:** [April 20, 2023, 12:29am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700 "2023-04-20T00:29:26Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Danny\_Lai](https://avatars.discourse-cdn.com/v4/letter/d/35a633/32.png) [@Danny\_Lai](https://community.frame.work/u/Danny_Lai)\
**Post date:** [April 20, 2023, 12:29am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700/1 "2023-04-20T00:29:26Z")
</div>
My laptop is a framework 13 inches 11-th gen Intel CPU with 32 GB ram + 1 TB + windows 11
After pressing power button, the power button is lit but the screen is completely black .
After more than 10 seconds , the power button turned dark and the screen stayed black .
Then I saw a series of blink LED ( White ( W) → Green ( G) or Red ( R) )
See my youtube video showing the blinking →
[April 19, 2023 - YouTube](https://www.youtube.com/watch?v=FQKyGkfysOo)
I recorded the blinks as follow
Blink# – Color ( W , G , R )
1. G
2. G
3. G
4. R
5. G
6. G
7. G
8. G
9. G
10. R
11. G
12. G
13.
R
14. G
15. G
16. G
17. G
18. G
19. G
20. G
21. G
The screen stayed blank . Please help !!!
**Author:** ![lbkNhubert](https://avatars.discourse-cdn.com/v4/letter/l/e19b73/32.png) [@lbkNhubert](https://community.frame.work/u/lbkNhubert)\
**Post date:** [April 20, 2023, 1:10am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700/2 "2023-04-20T01:10:42Z")
</div>
Sorry to hear that. Do you have an external display that you can connect to see if it shows anything?
Otherwise, this article: [My Framework Laptop (Intel 11th Gen Intel® Core™) is not powering on](https://knowledgebase.frame.work/my-laptop-is-not-powering-on-ryQLXvQkt) will help you understand the initial set of codes. There’s a link at the end of the page that discusses resetting the mainboard. If you do so, be careful with the RTC battery, the holder is extremely fragile.
**Author:** ![Second\_Coming](https://sea1.discourse-cdn.com/flex001/user_avatar/community.frame.work/second_coming/32/29330_2.png) [@Second\_Coming](https://community.frame.work/u/Second_Coming)\
**Post date:** [April 20, 2023, 2:18am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700/3 "2023-04-20T02:18:45Z")
</div>
Waiting for the rework v2 to hopefully fix this “not power on” symptom:
> [@Rework Instructions for 11th Gen Mainboards to enable powering the RTC circuit from the main battery](http://community.frame.work/t/rework-instructions-for-11th-gen-mainboards-to-enable-rtc-battery-charging-from-the-main-battery/26922/40):
> Extending upon this plan: [image]
**Post date:** [April 20, 2023, 2:20am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700/4 "2023-04-20T02:20:53Z")
</div>
After I pressed the power button , it turned off by itself in about 20 seconds . The screen was black throughout the process . I recorded a video of the process . Please visiting the following link →
[![](https://us1.discourse-cdn.com/flex001/uploads/framework3/original/3X/9/0/902bc8978f99f8f4804767e6f877a420bd13408a.jpeg "April 19, 2023") ](https://www.youtube.com/watch?v=FQKyGkfysOo)
**Post date:** [April 20, 2023, 3:35am UTC](https://community.frame.work/t/laptop-will-not-power-on/29700/5 "2023-04-20T03:35:58Z")
</div>
Yes, saw that video from the first post.
Background:
> [@Viability of an ML 1220 rechargable battery for RTC | CMOS (11th gen)](http://community.frame.work/t/viability-of-an-ml-1220-rechargable-battery-for-rtc-cmos-11th-gen/17664):
> I have been having some issues powering on my laptop for about a month. Every weekend, I try to turn on my laptop, and it refuses to do anything. Some mixture of removing parts like the SSD, RAM, or WiFi card seemed for a while to help, but every time, I would still need to plug in the laptop. After contacting support, they said that the RTC battery was likely dead, and to leave the laptop charging for 24 hours for the RTC battery to recharge. The battery is rated for 3V, but after charging fo…
There are various symptoms to this. What you’re experiencing is one of the symptoms.
Could your symptom be caused by something else? Sure. But you need to eliminate the most likely cause first…then go from there, to less likely causes (elimination tactic).
