Laptop would not charge or turn on
I had an unusual issue that occurred with my Framework laptop.
I have not used my Framework laptop for almost a month. Last night I decided I wanted to charge the battery the format a external drive to use as I want to dual boot with Windows and Linux with the laptop. I connected the power supply and noticed immediately the battery charge light didn’t turn on. So I attempted to turn on the laptop and nothing, not even the power light on the finger print reader/power button came on.
I removed the modules except for 1 and nothing… Tried connecting the adapter directly to the port and nothing. Next I thought it was the battery so I took the keyboard off but also check the connection on it and it was good. Disconnected the battery and reconnected the power and nothing. So I look at the CMOS battery thinking it could have gone bad and I need a replacement but then I saw it said rechargeable. I decided to take the CMOS battery out and waited 10 seconds to take a gamble and see if the CMOS needed to clear.
Put the CMOS battery back in and connected power back and the charge light came back on and I can turn on the laptop but it take a little for POST to kick in but it is working now.
I just found it odd. Could the reason be is because I had it not used it for so long and the CMOS battery needed to be recharged and/or reset by removing it?
Has anyone else experiencing similar issue?
Thank you
4 posts were merged into an existing topic: Laptop won’t power on unless i plug in AC power
