Context
I’ve just received my framework laptop 12th gen and I’m very happy with it. I installed Fedora first, everything was fine, then I tried Manjaro, it was ok.
Problem
For both of those distros I could not plug my external monitor with a proper thunderbolt cable through the USB-C port of my laptop to the thunderbolt 3 port of my monitor. If I plug it, I can hear a connecting sound, then a disconnecting sound, over and over and over.
Logs
When I run dmesg -w
just to observe what’s happening here, I can see this:
connecting sound
[ 1078.254281] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1078.254287] usb 3-2: SerialNumber: E80000816081
[ 1078.255563] hub 3-2:1.0: USB hub found
[ 1078.255644] hub 3-2:1.0: 4 ports detected
[ 1078.367668] usb 3-2: USB disconnect, device number 12
disconnecting sound
[ 1079.186824] usb 3-2: new high-speed USB device number 13 using xhci_hcd
connecting sound
[ 1080.220770] usb 3-2: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 1080.220788] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1080.220794] usb 3-2: SerialNumber: E80000816081
[ 1080.221932] hub 3-2:1.0: USB hub found
[ 1080.221991] hub 3-2:1.0: 4 ports detected
[ 1080.336357] usb 3-2: USB disconnect, device number 13
disconnecting sound
[ 1081.700203] usb 3-2: new high-speed USB device number 14 using xhci_hcd
connecting sound
[ 1082.734011] usb 3-2: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 1082.734022] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1082.734026] usb 3-2: SerialNumber: E80000816081
[ 1082.734995] hub 3-2:1.0: USB hub found
[ 1082.735019] hub 3-2:1.0: 4 ports detected
[ 1082.859733] usb 3-2: USB disconnect, device number 14
disconnecting sound
[ 1083.550258] usb 3-2: new high-speed USB device number 15 using xhci_hcd
etc, etc…
Question
Do you guys have any idea of what’s happening here ? I think it may be a firmware issue. Video output through HDMI is working fine, but I need to use my computer closed and connected to an external display with thunderbolt
Material
The screen I’m currently using: https://www.lg.com/us/monitors/lg-38wn95c-w-ultrawide-monitor
Both of the distros where up-to-date
Hope you could help me !
